D16 Y8 build
Old Dec 14, 2012 | 04:54 PM
JTR_HATCH_EG's Avatar
Icon6 D16 Y8 build
Hey I have a D16 Y8 head and am planning on finding a bottom and then building it. I am going to put YCP vitara pistons with eagle rods and ARP bolts in the bottom end. I was planning on replacing the springs in the valvetrain, I was just wondering if it would be worth it. I am trying to reach 300 HP after it is all said and done with the build and boost. Also how many cc injectors should i get? And would it be worth it to get a stage 2 cam shaft? Any information helps thanks.
Old Dec 14, 2012 | 05:57 PM
meda215's Avatar
building the bottom end like that is perfect but if ur gonna be boosting u have to get sum low compression pistons......the head can hold a lot.....I've meet Someone at the track running 11 flat with a stock head boosting 30 lbs n I not telling u to do it lol jus letting u kno but a cam will always be good it will reach ur 300 whp faster.....take ur time with ur build it will be better
Posted from Honda-tech.com App for Android
Old Dec 14, 2012 | 07:02 PM
97_ek_coupe's Avatar
Default Re: D16 Y8 build
300whp can be done with only pistons
Old Dec 15, 2012 | 02:30 PM
meda215's Avatar
y would he drop a d17 crank in......jus build how u were thinking in the first place......u r going going to boost right??
Old Dec 15, 2012 | 02:37 PM
grumblemarc's Avatar
The Grumpiest
Reading comprehension.
Old Dec 15, 2012 | 05:11 PM
ya imma boost, and i am going with DSM 450 cc injectors, i am planning on takeing my time and doing this right, also i thought YCP pistons were low compression, like 8:5:1, thanks for the input
Old Dec 15, 2012 | 05:17 PM
Also will block notching be required
Old Dec 15, 2012 | 05:33 PM
The Grumpiest
Depends on the rods.
Old Dec 15, 2012 | 05:51 PM
Marvin1985's Avatar
To throw this out there. Will an I beam rod not require notching of the block?
Old Dec 15, 2012 | 05:55 PM
The Grumpiest
https://www.google.com/webhp?sourcei...w=1829&bih=845
Old Dec 15, 2012 | 06:07 PM
Eagle rods will require block notching, possibly girdle notching. Id get better rods Though. Do some research, the pistons will not sit flush with the deck of the block with Vitaras. Compression will be more like 7:5:1.
Also, id get a little bigger injectors. Dsm 450s might do the job, but if you decide for more power, youll have to buy higher cc injectors.
Old Dec 15, 2012 | 06:10 PM
The Grumpiest
Custom length rods will up the compression of the Vitaras to a more "usable" level.
http://p2p0.com/#!/~/product/categor...050&id=5755445
Otherwise it will be a dog out of boost.
Old Dec 19, 2012 | 01:54 PM
Hey thanks for the link man
WHY7SPOOLIN
Jan 20, 2014 08:19 AM
96hatchie
Oct 17, 2009 10:58 AM
slob20ef
Jun 5, 2009 06:05 PM
nicko360
Oct 23, 2007 07:37 PM
98civicEX
Dec 19, 2002 02:44 PM
