EGT and Wideband tap ?
Old Oct 19, 2002 | 11:32 AM
cokex's Avatar
Default EGT and Wideband tap ?
so how many people have there EGT probe in the dp ?? and how accurate are the readings compared to having it in the manifold ?
also.. for the Wideband bung.. is there a distance in the dp that should be followed ?
[Modified by cokex, 8:32 PM 10/19/2002]
Old Oct 19, 2002 | 11:49 AM
BudaKai's Avatar
Default Re: EGT and Wideband tap ? (cokex)
The turbo adbsorbs a lot of the heat it won't be accurate at all. I'd move it to the manifold.
Old Oct 19, 2002 | 12:27 PM
dust's Avatar
Default Re: EGT and Wideband tap ? (tzsir)
ditto. put it on the number three runner about an inch from the flange.
Old Oct 19, 2002 | 03:16 PM
cokex's Avatar
Default Re: EGT and Wideband tap ? (dust)
its just so much trouble to tap the manifold.. have to unbolt the damn turbo and stuff..
who here has it tapped in the dp ?? i'm sure there are a few ...
Old Oct 19, 2002 | 03:58 PM
shadowdawn's Avatar
I have it tapped in the dp at the flange where it meets the turbo.... I wouldn't know how accurate it is compared to 3rd runner.... but it reads fine, just a little slow moving but thats probably because its a gauge and not digital
Old Oct 19, 2002 | 06:42 PM
Jared's Avatar
Default Re: EGT and Wideband tap ? (shadowdawn)
EGT should be on #3 because its the hottest cylinder and distance from the head is determined by your primary size. It should be half the diameter of your primary from the head.
allblackgsrt
Welding / Fabrication
Dec 19, 2005 06:59 AM
slowsi00
Mar 11, 2003 02:17 PM
uneekcrx
Sep 8, 2002 07:59 AM
FBP Si 2000
Mar 23, 2002 07:12 PM
Crxlsturbo
Aug 5, 2001 01:05 PM
