Piston ring orientation
Old Dec 12, 2012 | 04:26 PM
boostedteg4dr's Avatar
Default Piston ring orientation
In the diagram where is the engine front????
I have always used the engine snout or timing belt side as the front. If I clock the rings that way the top and second compression ring gap will line up the major and minor thrust sides. I never like lining gaps up with thrust sides.
And yes I know the rings rotate. I just want to set them correct for start up.
thanks
Old Dec 12, 2012 | 04:45 PM
Crx_owner_20's Avatar
Default Re: Piston ring orientation
The front is the timing belt side.
Old Dec 12, 2012 | 05:00 PM
SPOOLINmatt's Avatar
do not use that diagram
Old Dec 12, 2012 | 05:05 PM
There you go sir..
Old Dec 12, 2012 | 06:39 PM
its the diagram JE sent with the pistons. ????
Old Dec 12, 2012 | 07:41 PM
Use the above or the Honda manual diagram. You never want a comp ring gap on a thrust face, especially the top ring on the exhaust thrust face
Old Dec 13, 2012 | 02:47 PM
In the above diagram what is considered the engine front?
Old Dec 13, 2012 | 03:14 PM
Timing belt side.
Old Dec 13, 2012 | 04:34 PM
Originally Posted by Crx_owner_20
Timing belt side.
After a little research it looks like the diagram showing "the front" is actually the exhaust side. ??????
D16eg8
May 22, 2015 11:03 AM
SpyLude92
Sep 6, 2004 09:19 AM
LB CRX
Jul 15, 2002 02:45 PM
