t3 vs t4
Old Oct 19, 2002 | 08:45 AM
ludelvr's Avatar
Default t3 vs t4
just a quick question on compressor ar's. How much of a difference is there between a t3 with a compressor ar of .60 vs a t4 with a compressor ar of the same size? I know we're talking volume, but how and why is there such a difference? thanks
Old Oct 20, 2002 | 02:59 PM
ludelvr's Avatar
Default Re: t3 vs t4 (ludelvr)
ttt
Old Oct 20, 2002 | 03:03 PM
PrecisionH23a's Avatar
The t4 exhaust housing tends to be a little more laggy then the t3 does
Old Oct 20, 2002 | 04:07 PM
ludelvr's Avatar
Default Re: t3 vs t4 (GudeH23a)
How much more volume does the t4 push out than a t3? Cuz like I said, both having the same compressor ar of .60, how can a t4 generate so much more power?
Old Oct 20, 2002 | 06:47 PM
Quiz's Avatar
https://honda-tech.com/zerothread?id=299174
Old Oct 21, 2002 | 08:04 AM
ludelvr's Avatar
Default Re: t3 vs t4 (Quiz)
Dude, That has got to be one of the best explanations I've had here on a long time! Thanks man!!
One more thing though, would it be plausible to put in a compressor blade from a t4 in a t3 housing or would it create too much heat? Moreover, would it be possible to stick in a different wheel and keep my current housing? Thanks again man!
Old Oct 21, 2002 | 06:52 PM
ludelvr's Avatar
ttt
Old Oct 22, 2002 | 09:36 AM
Quiz's Avatar
It's possible to fit larger wheels in the smaller housings. Depending on the dimensions you may have to get the compressor housing machined, and maybe the back plate, to fit the larger wheel. As far as how efficient this will be, I'm sure it will be fine to a certain point. But what that point is I don't know. My personal rule of thumb was stay in the T# familly. Talk to a turbo shop. You also have the option of replacing the wheel, housing, and back plate with the T4.
[Modified by Quiz, 1:39 PM 10/22/2002]
Old Oct 22, 2002 | 02:21 PM
ludelvr's Avatar
How much bigger is a t4 housing than a t3? Mine in particular is pretty big and my both my friends with a t3/t4 said it's about the same size.
Old Oct 22, 2002 | 04:30 PM
shadowdawn's Avatar
well a t3/t4e will be descently bigger then any t3..... a t3/t4b on the other hand isen't much bigger then a t3's compressor housing... my e looks considerably bigger when paired next to a friends b
Old Oct 22, 2002 | 10:05 PM
ludelvr's Avatar
Default Re: t3 vs t4 (shadowdawn)
I only ask cuz mine is a fairly large t3. when compared to the t4 that comes in the drag kit, it's quite similar in size. Anyway, it's more of a space issure. How easy is it to change out the cold side of the turbo?
PINKS
Aug 28, 2006 05:16 PM
s1ngle
Jun 9, 2005 04:44 PM
RudeLude
Jan 31, 2004 02:58 PM
JalopySiR
Feb 7, 2003 06:48 PM
Pat
Oct 13, 2002 03:12 PM
