Good Compression Test Results?
Did a compression test on my 98 Honda Accord, 4 cyl.
Got 210psi right across. Is this possible? I followed all steps in the Haynes Manual accordingly.
Did you remember to keep the throttle body wide open while cranking the engine? I can't remember if the Haynes manual mentions that or not.
That is a lil high. About 184 is spec. I'll double check that though. Are you cranking 2 full compression cycles or are you cranking till the gauge stops climbing?
Well next time you check watch the gauge and the second time the needle jumps, that's where your reading should be at. Make sure the fuel pump relay is removed so you don't wash down the cylinders. You'll get a low reading
