Motor temp. and Rev Issues
Old Dec 2, 2012 | 03:18 AM
BIGef's Avatar
Default Motor temp. and Rev Issues
1989 Civic 4 door
obd1 B18
Bone stock except Dc headers and 2.5" exhaust
New fuel filter
New intake manifold gasket
Alright ive noticed when I let the car idle (COLD Start) and 10 mins later Motor get really hot. Even to the point where i touch the distributor bolt its super hot.
and whenever i Rev(Vroom Vroom) car idle drops to about 500rpm then goes back to regular idle(750 rpm)
Sometimes it will bounce up and down 500-800 then back to 750 rpm.
Any one have any ideas what could cause this?
timing? plugs?
Old Dec 2, 2012 | 05:30 PM
TKATS_EF's Avatar
Default Re: Motor temp. and Rev Issues
Timing can be a big factor. plugs may also be a factor but not one that would make a drastic change. Either your timing is way off or you may also have a vacuum leak that will make the fuel mixture lean and raising temperature. Now i know you said the distributor bolt gets hot...but what does the temp gauge read?
Old Dec 2, 2012 | 05:39 PM
meda215's Avatar
yea what is the gauge reading
Posted from Honda-tech.com App for Android
Old Dec 3, 2012 | 01:56 AM
BIGef's Avatar
temp guage reads normal.
Its on the half line.
So timing is the only issue i have causing the heat?
Old Dec 3, 2012 | 08:36 PM
TKATS_EF's Avatar
looks like the engine temp is normal by what youre telling us. unless your gauge starts climbing i wouldnt really worry about the "heat". now on the idle...you might have a vaccum leak or just need an idle adjustment
Old Dec 3, 2012 | 09:11 PM
BIGef's Avatar
Ive own other Efs and never got this hot before.
Old Dec 4, 2012 | 07:46 PM
BIGef's Avatar
anyone
Old Dec 14, 2012 | 07:33 AM
meda215's Avatar
i dont think u have a problem i think its normal i cant touch my dizzy after car is at operating temp.....its metal so gets extremely hot no matter what.....best thing u can do is check ur coolant make sure its full with no air bubbles....if u still dont like the temp use a thermostat that opens at a lower temp
Old Dec 18, 2012 | 06:52 PM
BIGef's Avatar
This is what my car has been doing when revving
http://www.youtube.com/watch?v=Ce8Mt...ature=youtu.be
gooblinn258
Dec 12, 2013 06:21 PM
trevek10
May 16, 2011 03:07 PM
b16a4
Sep 12, 2007 06:02 PM
bassysingh
Oct 17, 2005 10:02 AM
Chronicsinners
Feb 4, 2005 02:41 PM
