kelford 176 -B camshafts need helpwith info
Hello honda-tech,
I plan on buying cams for my for my B18c/B18a set up and I found spec on the kelford 176-B cams but I wanted some one opinion on these cams vs other cams that they used what are the pro and cons to these cams and sorry if it doesn't make sense I'm a noob sorry again
you need to help us.
What are the specs?
I never heard of Kelford Cams. But why not use cams that are tried and true for your engine?
What are the specs?
Kelford makes quality cams for other makes such as the Evo. I believe K-series users have had success with them as well. When comparing advertised specs, it's hard to say how they will do vs another cam. best thing to do would be to try them out if u r interested.
Most of the reputable companies publish their cam specs, so grab the charts for the cams you are interested in and compare them. Do some research and searching on here for what the differences in the specs mean for your engine and what you want out of it (duration vs lift, etc).
^^ yea that's a good idea. unfortunately, the advertised specs are not always accurate... though it'll give u a good idea. also.. knowing the lift and duration of a cam will give u only an idea of how it'll perform, but then again... that's not all there is to it.
jetblack
Feb 22, 2009 10:00 AM
rice4life
13
Feb 24, 2002 08:33 PM
