newb needs help with turbo question.
what are the differences between the TD04, T3/T4, T3/T04E, etc, etc...??? what's the differences in the brands like Revhard kits, Greddy kits, Fmax, etc..?? are some better then others?
i have a EK hatch and am planning to turbo my stock SOHC motor - is there a specific one i should get?
thanks for the help.
i will try to answer but your questions are a bit vague. I never though I say this but the search method really works.
The td04-15g for the sohc is good for the street. quick spool up time
The rest that u mentioned are generally good for top end and more power. They don't take that long to spool, but when they do watch out.
It all depends on what u want for the motor. Do a search on those kits u mentioned and u will find alot of info from guys who have already gone down that route.
Good answer above if you are staying stock I'd reccomend the greddy if you want big power "forged internals" rev hard etc . State your goals.
my goals are to run around low 14's. i'm also going to build my motor so i can boost around 12 psi.
i did a search and it seems that most people have the T3/T4.
nochance
Jul 29, 2003 07:50 AM
