Strange Idling
Old Nov 23, 2012 | 10:24 AM
Project97EX's Avatar
Default Strange Idling
I have a 95 Civic Ex with a D16Z6 and it is turbo with a T25 DSM turbo at 8 psi. It is idling strange. It idles at 1500 and pulses slightly, in first and second gear, if i don't keep it at high RPMs it jerks back and forth pretty hard. I have searched all over this sight trying to figure this out. I have replaced the MAP and TPS sensors, cleaned the throttle body, and it was still running strange. I checked the ECU codes and it is throwing a 14 which is an IACV code, so i pulled that off my 97 civic, which i was building (hence my user name) but it got hit...so i took of the IACV and put it on and the 95 and it is still throwing the code. The weird part is, that it stops pulsing and stays at a steady 1500 when the radiator fan kicks on. I've tried everything i can think of. Any help would be greatly appreciated. Thanks in advance.
Old Nov 23, 2012 | 10:31 AM
97_ek_coupe's Avatar
Default Re: Strange Idling
Might sound silly, but when you replaced the tps, did you set it to the correct voltage?
Old Nov 23, 2012 | 10:32 AM
I was gonna check that but i need to go buy a meter. I'll do that.
Old Nov 23, 2012 | 10:35 AM
I believe it should read .5 closed, and 4.5 while throttle is completely open. The meters run pretty cheap at autozone (i picked one up for $15).
Old Nov 23, 2012 | 10:44 AM
Ok. What wires do i check on it. I can't remember.
Old Nov 23, 2012 | 10:53 AM
You check the wire that runs in the middle to the tps of the three that are there. Hope it fixes your issue man.
Old Dec 1, 2012 | 05:17 PM
It reads .3 Closed and 4.2 Open.
Andrew Ryan P
Mar 20, 2017 07:48 PM
ricer wes
11
Aug 4, 2011 09:59 AM
xander1100
Aug 17, 2009 12:10 AM
ludacole
Aug 13, 2005 11:59 PM
Jdm_Rice_Monster
Jan 14, 2003 07:34 PM
