B20 CRX Won't Start!
Old Nov 22, 2012 | 05:50 PM
B20vCRX's Avatar
Icon6 B20 CRX Won't Start!
I purchased A 1990 CRX with the B20 Vtec swap. I drove the car for two days, then one day I decided to go for a little cruise. I hopped in the car and the car just continuously turns over with no spark throwing CEL 15 Ignition Output Signal. I tried a different distributer and still nothing, Im getting power to it though.
I also tried relays, Checked ecu, And checked all the grounds. The car is currently at another Honda Tech members garage being worked on. I figured I would make a post for further help.
I wanna also throw out there the the wiring throughout the car is a mess! Any suggestions? Would be highly appreciated! Thanks again guys!
I understand this could be in the wrong thread. But I wasnt getting any further information in Element/Crv. Even though it is a b20 engine. It is a 90 CRX.
There's voltage at the ecu ignitor output and at the dizzy, yet get no spark. Even tried a different ecu.**
Old Nov 22, 2012 | 06:03 PM
1998GsRIntegra's Avatar
Default Re: B20 CRX Won't Start!
Just for the hell of it...unplug the alternator and see if the car will fire up. Just the green plug that goes to it from the main harness. Had a very similar problem in my dads race car(back then it was a b20v crx). Turned out the voltage regulator in the alternator was bad. As a result, for some wild *** reason, no spark and the car would just crank and crank and crank. Spent a long time diagnosing that one and ended up finding the problem by pure fluke anyway. Replaced the alternator and problem solved. The car will just run off of the battery if the alternator is unplugged so dont worry, you are not going to mess anything up by doing it. Worth a try if nothing else.
Clean up the wiring too. The harnesses in those cars are 20 years old and who knows how many times they've been fucked with. I'm in the process of re-doing the electrical system in my dads car for the same reason. 20 years old, cracked wires, ghetto rigged ****, so many butt connectors...I spent about 5 hours just replacing wires, and removing butt connectors from the engine harness. So much soldering...
You may also want to throw threads up in the crx forum as well as the hybrid forum.
Old Nov 22, 2012 | 10:51 PM
B20vCRX's Avatar
I will be trying that tomorrow!
Old Nov 22, 2012 | 10:52 PM
B20vCRX's Avatar
And this thing is butt connector he** haha, The harness is in pretty bad shape. I really appreciate your respond though!
Old Nov 23, 2012 | 12:30 PM
B20vCRX's Avatar
Bump!
Old Nov 23, 2012 | 05:23 PM
EJ-1's Avatar
check the harness, distributor cap, rotor button.
Old Nov 23, 2012 | 05:34 PM
blade890's Avatar
well before getting into the mess with the wiring harness have you tried checking the plugs and wires some times thay may cuase the car from not starting
Old Nov 23, 2012 | 05:50 PM
PhilStubbs's Avatar
Wiring is one of those things that, if it looks bad it probably is. Anytime I get a car to tune that has 2 wiring problems before I get past tuning the idle, I send them away till they clean it up. Wiring can cause very odd problems that don't make any sense.
Old Nov 23, 2012 | 06:32 PM
blade890's Avatar
well worse comes to worse just replace the wiring harness best thing you can do
Old Nov 24, 2012 | 09:03 AM
B20vCRX's Avatar
I'll try what you guys said, I appreciate the help guys!
Old Nov 24, 2012 | 07:23 PM
B20vCRX's Avatar
bump!
Old Nov 25, 2012 | 11:13 AM
B20vCRX's Avatar
Bump!
Old Nov 26, 2012 | 11:25 AM
B20vCRX's Avatar
Monday bump!
Old Dec 12, 2012 | 02:35 PM
B20vCRX's Avatar
Bump, still no spark!
Old Dec 15, 2012 | 04:46 PM
B20vCRX's Avatar
bump!
Old Dec 15, 2012 | 09:49 PM
egcoupe918's Avatar
seems we just habe really bad luck I havw talked to several "honda experts" and they have no idea why I dont have spark either
Posted from Honda-tech.com App for Android
Old Dec 16, 2012 | 03:26 AM
Disco's Avatar
Main relay, igniter, coil, ecu, there isn't much that will cause a no spark condition like your experiencing.
Old Dec 17, 2012 | 08:54 AM
B20vCRX's Avatar
Tried that :/
B20vCRX
Jan 5, 2013 09:35 PM
B20vCRX
Nov 22, 2012 02:44 PM
B20Noobie
Nov 14, 2012 06:11 PM
91highryda
Sep 24, 2006 09:34 PM
Lm546
Nov 1, 2002 03:39 AM
