Hey B series builders Can this be done?
Old Nov 20, 2012 | 04:53 PM
metalhelixx's Avatar
Default Hey B series builders Can this be done?
I have a BONE stock b16a, the rings are starting to go out so I'm thinking of just tearing down the block and making an improvement can I use 81.5mm Nippon b16b pistons and have the cylinders bored to fit the pistons?
http://www.ebay.com/itm/Nippon-Racin...-/160899481979
Looking to build a streetable motor, raising a bit of compression, and i'm reusing my stock rods.
Old Nov 20, 2012 | 04:58 PM
1998GsRIntegra's Avatar
Default Re: Hey B series builders Can this be done?
Can it be done? Yes
Old Nov 20, 2012 | 05:07 PM
Originally Posted by 1998GsRIntegra
Can it be done? Yes
What sort of things do you guys recommend me doing during the rebuild, it just needs rings, but I want to make more power so what sort of things can I do while the block is apart.
I want to make at least 170 to the wheel.
Old Nov 20, 2012 | 05:32 PM
doood's Avatar
been there done that
might as well replace all seals and bearings while it's apart
Old Nov 20, 2012 | 05:41 PM
LTCxD2B's Avatar
arp rod bolts
Old Nov 20, 2012 | 09:12 PM
yeah i'm going to do all the seals and bearings, but i already replaced those 9k miles ago I just had the motor rebuilt it's just I did the swap wrong and wired the resistor box and my injectors dumped a lot of fuel and f'd up my rings.
Old Nov 20, 2012 | 09:30 PM
angryhillbilly's Avatar
9k miles on bearings? There prolly fine. But I would make that judgment call when u see them. Other things to think about changing while your down there. Water pump. Oil pump. Timing belt. Arp head studs. Rod bolts if you think its necessary. Other than that. All the power is made in the head.
Old Nov 20, 2012 | 10:50 PM
okay, great thanks where can I find arp head studs for a good price? Would I be sacrificing anything using 81.5mm pistons I heard it's not safe to rev high with heavier pistons.
Old Nov 21, 2012 | 03:00 PM
CTR pistons are already heavy, if your using them the extra .5mm isn't going to make any difference. The ship has sailed on that domain so to speak.
1991ED6
May 10, 2013 11:15 AM
TravisBiggie
Apr 10, 2013 08:21 AM
b16bri
Oct 11, 2010 05:39 PM
424racer
Jul 31, 2010 07:19 PM
eddie1681
Jun 19, 2002 04:06 PM
