spark plug color
hi
since i tuned my car i removed to check my spark plugs twice.
first time was like this :
all cylinders was almost the same
it was not a wot pull on 3rd or 4rth gear i just parked my car and removed them to check.
what are these white marks on them ?
second :
still some white marks on them and porcelain is black ?
engine is a b18c5 with i/h/e and tuned p28 ecu with rdx 410cc injectors.
i use ngk bkr8eix plugs .
second :
First off, your plugs are waaaaaasyyyyyy too cold. Put some 6's in there if its stock compression. Also looks a little rich, pic isn't clear enough to judge timing, but all that's out the window with the wrong plugs anyway.
Phil is right...Wayyyy to cold. i am in the 7 heat range at almost 500whp. 6's is where you want to be....get bkr6eix
You might want to get the bkr6eix-11 if your not turbo, nitrous , really high compression ect
usually i drive small distance from my job to my house.
can now shift to #6 range without any problems ? ?
in gental cruising you will run more lean for mpg's its fine to have some white their. now if you were ripping on it right before you pull them and theres white then that may mean your afrs are lean at wot.
zombo
May 3, 2011 06:27 PM
ILLICON3000
Sep 20, 2004 07:45 AM
