Moisture inside my BB6
Old Nov 11, 2012 | 03:19 AM
Draiga1988's Avatar
Default Moisture inside my BB6
Ok I'm not sure what is causing this but so far everymorning I have came out there has been moisture on the inside of every one of my windows idk y my carpet is also wet as well not sure why the windows were up I cleaned them off an the next day the same thing happened I'm gonna try a see if the sunroof is leaking water in to give moisture inside but idt that is it if you've had this issue please let me know any info on it.
Old Nov 11, 2012 | 10:59 AM
bigblue7t6's Avatar
Default Re: Moisture inside my BB6
Most likely the tail light seals. Check in your trunk under your spare and see if its holding water. Tail light seals was the problem on mine, the back floor boards were wet also. If not it can be the sunroof drains like you said.
Old Nov 12, 2012 | 05:37 PM
96-h22a1's Avatar
From what I've noticed taking my sunroof panel off the drainage on it actually really good. Not sure if it's the same on a 5th gen but each corner of the sunroof has a rubber hose connected to it that drains the water out the front/back of the car so I doubt it's coming from there
Old Nov 12, 2012 | 08:26 PM
yroachy's Avatar
+1 on the tail light seals. Happened to my buddies fifth gen. Water pools in the trunk and gets sloshed into the passenger compartment when you brake. The carpet was wet u fee the passenger seat.
Old Nov 16, 2012 | 02:21 PM
Draiga1988's Avatar
Well Im pretty sure it's the tail light seals for multiple reasons lol one there is moisture in the bottom of my tail lights second I checked in my spare bay In the trunk an it is full of water an it froze lol about an inch or 2 thick lol. How would I go about to fixing this like tail light seals an the moisture under the back seats an the front carpeting.
Old Nov 16, 2012 | 07:04 PM
cullylude05's Avatar
Pull the rubber plugs in the trunk floor out. two plugs about half dollar size. That's first off so when water gets in it will drain back out for now. Next I would check to c if your rubber seals on the taillights r in fair condition and on right (they do have a side to them one goes against the car And other against the taillights. I would get some rubber ribbon tape or seal (think that's what it's called) or shop term dum dum. Clean your taillights where it meets the taillight pocket and put some on to fill the gap. May help
Old Nov 16, 2012 | 07:21 PM
For the back seats pull them out and put in your house with a fan blowing to dry them up, the bottom seat will have two spots that u pull a tab out towards u, this unlocks the bottom part. The tabs r in the middle of each backseat and right were the seat and the floor meets. Pull the seat up a little to c the the black tab on each side And pull that out towards u, sometimes it's a little hard to get to unlock. that bottom part will now come out. Good luck, been down this road too.
Old Nov 17, 2012 | 10:22 AM
Draiga1988's Avatar
Thx man I'm off this Tuesday an wed so I know what I'll be doing lol
Old Nov 17, 2012 | 01:29 PM
Good luck
b20bFourDoorCivicLX
Oct 14, 2012 09:57 AM
liyan1430
Honda S2000
Apr 21, 2012 02:34 PM
b17itr
Oct 5, 2011 04:58 PM
dnunes
Aug 28, 2011 03:50 PM
pprowler6
Mar 13, 2011 10:07 PM
