d16y7 intake manifold
Old Nov 6, 2012 | 08:24 PM
racerx510's Avatar
Default d16y7 intake manifold
its ugly, i hate this thing, i run 600 miles/week on the car, looking for a better intake manifold while i start cleaning things up under the hood. the skunk 2 is great, i like the d16y8. what oem one's will fit on with the y7. thank you much h.t.
Old Nov 6, 2012 | 08:28 PM
racerx510's Avatar
Default Re: d16y7 intake manifold
i read something a while back (my car is a 96 ej hatch), that i need a 96-98 d16 y8 automatic manifold to make things easier
Old Nov 6, 2012 | 08:41 PM
B20DelSol's Avatar
Yup...D16Y8 automatic transmission intake manifold will work. I have one for sale if you are interested...with TB, injectors, and fuel rail. Let me know, PM if you are interested! I don't have performance numbers but it at least makes your engine bay look a lot better
Old Nov 6, 2012 | 11:31 PM
racerx510's Avatar
i understand theres a minimal advantage due to the intake runners opposed to this dook-pod p.o.s thats sitting there now. i think the t.b, injectors and fuel rail and most other things i retain from the d17 but theres a part for the t.b i use from the y8. pm sent
Old Nov 7, 2012 | 12:32 AM
jbpnoman's Avatar
You won't need the injectors or rail. You will definitely want the TB with the manifold. You can use the whole unit to make life easier. If you decide (for some unknown reason) to use the old TB, you'll need to swap the rotor assembly from the Y8 unit onto the Y7. It's not exactly easy work. Just use the Y8 TB.
Old Nov 7, 2012 | 01:13 AM
HondaPartsHero's Avatar
Technical Hero
http://www.d-series.org/forums/diy-f...swap-pics.html
Old Nov 7, 2012 | 07:18 AM
racerx510's Avatar
Originally Posted by HondaPartsHero
you sir are a true gentleman!!!
Old Nov 7, 2012 | 07:34 AM
osbunjosh's Avatar
From my experience I wouldnt waste your time and money.... I just bought a 1998 civic hatchback. Came with a d16y7 all stock. Decided i wanted a little more power so i bought a d16y8 intake manifold and a catback exhaust. When i did my manifold swap i followed that same exact guide. Now i have a idle problem and still can not figure it out. My car pulls the same but a lot more noise. If i was you just save for a swap or build another D on the side.
Old Nov 12, 2012 | 11:07 AM
racerx510's Avatar
everything hooked up right? im not after the power im grabbin cus the oem y7 mani looks like crap and im trying to clean up my engine bay. i drive a lot, 460 on saturday alone for work. the next motor going in is a d16y8 anyways but oem for the mpg
tamadrumr88
Jun 19, 2014 01:16 PM
Wrona
25
Apr 21, 2011 12:27 PM
jdmf23accord
14
Dec 16, 2010 04:55 AM
Marauder
86
Aug 22, 2003 08:29 AM
