Serious hesitation on my '92 Prelude Si
Old Nov 5, 2012 | 06:34 PM
uncholowapo's Avatar
Default Serious hesitation on my '92 Prelude Si
It happens when I press on the gas from a complete stop and while I'm holding a speed at low RPM.
From a complete stop, say at a red light, the hesitation period varies. The shortest being 1/2 a sec. and the longest lasting almost 3-4 seconds. Right after it gets itself together, it pretty much launches me forward because I've pressed the pedal down for a good bit at that point.While I'm holding the speed, it lasts as long as I'm at that low RPM range, roughly around 1000-2000.
A little background, it is an automatic, H23A1. The spark plugs are new, all gaskets have been replaced, head was machined and has had the valves changed according to the seller. I've got a general understanding of cars but from V8's since I've driven them all my life. My mom's Expedition had almost the same problem and changing the spark plugs fixed the problem there. Unfortunately it didn't work here.
Any help would be awesome. Also, first post
Old Nov 5, 2012 | 07:08 PM
mherkamp's Avatar
Default Re: Serious hesitation on my '92 Prelude Si
Calibrate the TPS? Sounds like the throttle position sensor (TPS) may not have gotten put back exactly right or was replaced and needs calibrated. Search for that and you should be able to find the procedure. Also, if that doesn't work, you may need a new TPS, then make sure you cal it after install. If not, as you open the throttle, the computer won't know to add more fuel, so it hesitates.
Old Nov 5, 2012 | 11:49 PM
holmesnmanny's Avatar
Could be egr related. Pull the egr valve electrical connector and when it throws the code, which turns off egr, see if it still does it.
Old Nov 6, 2012 | 01:31 PM
I'll add both of those to the list of things to do for the weekend. Any other theories I could test out?
Old Nov 6, 2012 | 06:59 PM
Also, would replacing the cap, rotor and wireset do any good?
Old Nov 7, 2012 | 02:22 AM
Wiresets go for a long time, especially if it's NGK or OEM. Just go cap, rotor, and plugs.
Old Nov 7, 2012 | 11:58 AM
snobordboy's Avatar
Moderator
I am a bit confused, is it the engine hesitating, or is the engine building some rpm, but the car isn't moving?
Sounds a bit more like a torque converter or tranny issue should be examined as well at this point.
Old Nov 7, 2012 | 11:14 PM
1funryd's Avatar
Open up the distributor cap and check to see if your rotor has come loose because the screw holding it down might have backed out.
Old Nov 8, 2012 | 07:01 AM
No, its hesitating. Although the tranny does have some rough shifting while on the road. I'm not tackling that though since I'm converting to manual in the near future.
I'll definitely check that out. Anything that saves money is a good thing
92 h22a prelude
Mar 15, 2015 02:55 PM
Rey01ITR
Honda CR-V & Element
Jun 20, 2012 11:40 AM
civbomb
Oct 31, 2008 03:31 PM
RedGSR
Jun 24, 2004 09:17 PM
graphic
Oct 23, 2003 06:48 AM
