Stock b20 turbo?
but seriously, 5 psi is **** all. i'd say on a b20b (usdm) you wanna throw at least 7 or 8 psi at it. it's only like 8.1:1 compression on those.
if the motor's in even half decent shape and you've got a DECENT tune, 8psi all day no prob.
see my original post...
there are just way too many variables to throw out a decent assumption.
the stock b20b is a pretty low output hp motor. do yourself a favor and ditch the weak intake cam. opt for at least a stock 94 integra cam.
IMO, it's a great motor for boost. some arp head studs would add insurance. everybody says "the walls are too thin" but really? have they ever actually witnessed this failure? i sure haven't.
8psi on a good tune. dollar for dollar, it'll go faster than anything else at the same price.
just make sure you have everything to make it work right. it's not just a turbo, IC, and some pipes.
Saying the motor runs strong doesn't mean it's healthy. You need to do a compression test and maybe a leak down test.
Not knowing the engine compression is like high blood pressure...
10 psi from a gt28 is not the same as 10psi from a gt35. so psi is irrelevant without knowing exactly what turbo will be used and is pretty stupid when determining what an engine is capable of withstanding.
Yes, read the Forced Induction FAQ.
In the simplest sense, boost pressure is a measure of how restrictive a system is relative to what is being pushed through it. If you run a turbo full-blast into the atmosphere, it still moves a massive amount of air, but at 0psi. Similarly, take that turbo and hook it up to a very small 1" pipe...before it begins to move even a fraction of the airflow as before, it will begin to build boost (restriction) inside the pipe. For this reason, variations in efficiency, piping size, and a whole host of factors, can influence the power made per psi of boost...even for the same turbo. To this end, PSI is NOT a useful measure of power. It is important when choosing a MAP sensor, and thats about it
