99 SH spun rod
The 99sh has 55 mm main journal diameter and the h23 has 50mm mains so the answer is no they will not interchange,the 1997 h22a4 and 92-96 h22a1 has a 50mm main if u can find one of those short blocks u can rob the crankshaft , Hope this helps
Lets correct this a little bit
Main Journal Diameter
H22A4 = 55mm
H22A4 = 50mm (1997 Only)
H22A = 50mm
H23A = 55mm
H23A1 = 50mm
F22 = 50mm
F23 = 55mm
F20B = 55mm
like 98vtec said. If you have an h23a crank you will be able too
H22A4 = 55mm
H22A = 50mm
H23A = 55mm
H23A1 = 50mm
F22 = 50mm
F23 = 55mm
F20B = 55mm
To summarize: no, that crank will not drop into your existing block; you need the block specifically from a '97 SH - this is the only block that will work for you.
HotWheelz
Oct 16, 2002 06:33 AM
