???? oil leaking ????
Old Oct 24, 2012 | 03:58 PM
angeelokoe's Avatar
Icon2 ???? oil leaking ????
i have a 96 integra 1.8 so i got to work today and noticed my car was smoking looked under the hood and saw oil pooring out from under the distributor (where the weep hole is) towedit home. i thought it was the oring so i bought a new one from honda replaced it and its still leaking then bought the oring that goes in between the dist. cap and the distr. replaced it and still its l;eaking from the same lil hole under thje dist. ????? what else can it be it only leaks wen the car is running..... please help do i need a new distr.????
Old Oct 24, 2012 | 05:40 PM
EsotericImage's Avatar
Retired Moderator
Default Re: ???? oil leaking ????
if you have oil insid the cap, then get a new distrib..
if not, then maybe the cam cap isnt tight or the corner of valve cover needs some gasket maker.
If you need a distrib, i have one. PM me
ronk123
Apr 18, 2017 01:01 AM
emagdnLm
10
Aug 30, 2011 04:26 PM
dgdarien
Sep 8, 2009 04:50 PM
reapercivic88
May 2, 2007 09:59 AM
piggydog
Apr 9, 2007 07:05 AM
