Ati Damper Question H22
Old Oct 23, 2012 | 01:46 PM
patroick67's Avatar
Default Ati Damper Question H22
I have been trying to figure out what pulley to run on my ati race damper part number: 918469. I thought that this came with a pulley so that you could run your alternator. I called ati and they said in order to run an alternator with this damper I had to use a big block chevy pulley because of the 3 bolt accessory pulley style I have attached a picture if anyone can tell me what pulley part number or something like that to run that would be great as I can cross reference it at work(work at parts store). I am sort of lost at this point because I don't want to under-drive the alternator to much.
Old Oct 23, 2012 | 02:51 PM
ninesecrx's Avatar
Default Re: Ati Damper Question H22
Summit racing and jegs sell a ton of std chevy type pattern pulleys that will bolt right on. Just check them out online or crack open one of their mags.
ESP.net's Avatar
Stick with OEM even 800 hp H monsters still use OEM...
Old Oct 23, 2012 | 02:54 PM
zakura R's Avatar
I might have one I will get back to u in a few
Old Oct 23, 2012 | 02:59 PM
patroick67's Avatar
Ok, I guess my next question is how do I choose the correct diameter accessory pulley? If I go to small it will be under driven too much wont it? There are no electronics in the vehicle besides the fuel pumps, head lights, ecu, gauges, and dash lights. Or am i just over thinking this?
Old Oct 23, 2012 | 03:02 PM
patroick67's Avatar
If you do Zakura that would be great
Old Oct 23, 2012 | 03:12 PM
zakura R's Avatar
Ur pulley looks like it's for a bseries not a h22!! The h22 use the alternator belt where ur has the timing mark and the small pulley that u could attach to its for the power stearing pump just notice but I do have the pulley for if u want to try it
Old Oct 23, 2012 | 03:17 PM
patroick67's Avatar
Fml well I will double check the part number tonight when I get out of class. This is the "race version that is listed on ati website for the h22...ati said that the street version was the one with the belt where the timing marks are argh...can't send it back I no longer have the box
Old Oct 23, 2012 | 03:31 PM
crazes's Avatar
Moderator
well you can always try to sell and get the street version
Old Oct 23, 2012 | 03:48 PM
zakura R's Avatar
Call ati and ask them if u could use the small pulley from the st version for the power stering for ur alternator belt cuz I have that pulley.
Old Oct 23, 2012 | 06:25 PM
patroick67's Avatar
Okay I am 90 percent sure that this is the wrong ati super damper. It is part number 654782, I cannot find this part number anywhere?
Old Oct 23, 2012 | 06:32 PM
patroick67's Avatar
I'll call Ati again in the morning
Old Oct 24, 2012 | 06:06 AM
Innes's Avatar
i think i have the add on pulley you need for that h22 damper to run the alternator....i ran into the same issue on one we sold a customer and then the deal went sour so it is sitting here on the shelf - call me in the office and i can try and assist -- 407-324-4684
note, the h22 race damper part # should be 918469
Old Oct 24, 2012 | 03:02 PM
patroick67's Avatar
Thanks Innes, I gave you a call they said they didn't know where you were at the moment. I left my name and phone number. I checked and I did get the correct one and as long as I can get a pulley this one should work great! Thanks for the pulley as well.
Old Oct 24, 2012 | 03:14 PM
patroick67's Avatar
Okay, just in case anyone in the future ever gets a race ati damper for the h22 it does NOT have a pulley for alternator so in order to run the alternator you have to use the power steering pulley that ati supplies with there street version. I am going to test it here in the next couple of days to make sure that it doesn't under drive the alternator too much. I am really surprised that this has never popped up before. Ill report back to make sure that it works here in a couple days.
Old Oct 29, 2012 | 11:27 AM
patroick67's Avatar
Update: I received the power steering pulley from innes, this pulley should work no problem at all for anyone that purchases the h22 race damper. I have measured the pulley that I got and it is the same size as the factory h22 crank pulley. The part number on the box is 916338. The h22 race damper has no means of driving any accessory not even the alternator without this pulley!
Old Nov 1, 2012 | 01:27 PM
patroick67's Avatar
Well I tested the power steering pulley idea innes suggested, it doesn't work, after getting the timing set and the alternator on the civic it just flat out not possible to run an alternator with the race damper. Argh now I am about 500 dollars fml
Old Nov 1, 2012 | 04:33 PM
DxTrix's Avatar
What's the problem?
Old Nov 1, 2012 | 05:24 PM
patroick67's Avatar
The problem is the ati race damper for the h22 doesn't have a pulley for an alternator. The street version has a spot for the alternator where the timing marks are on the race version. I tried using the power steering pulley from the street ati damper on the race damper bc the pulley can bolt to the center part of the race damper. The only problem is when you do this the alternator and ati damper do not line up at all. The ati damper sticks out about two inch farther than the alternator pulley so this makes it unable to line up the alternator pulley and the pulley I bolted on the damper. I hope that explains it.
johnsc2235
Dec 17, 2013 12:30 AM
95EG2
Mar 14, 2011 06:44 PM
VT VTEC
Jan 12, 2011 11:57 AM
spyderracing
Aug 16, 2004 04:34 AM
(__________)
Sep 23, 2002 06:46 AM
