wierd Idle jump?
Wierd Idle play pretty much!
(I have a 92 DA teg LS)
ok I don't really know how to put this, but when the motor is cold of course you get the high idle and then drops to normal 700 idle.
here is the kicker, when motor has been running for a while the idle drops to 500 when I press the clutch or put the car is in neutral! smh
the car sounds and feel like it wants to die, but car never dies and it jumps from 500 to 700 constantly.
I tried to troubleshoot, I cleaned the ICV (idle control valve) I think that's what is called, adjusted the air/idle screw (lol don't judge me), I also shot with timing gun! all out of ideas!....
please if you had the same problem and fixed it....share info so I can fix my DA. Thanks
Last edited by DAmunster671; Oct 19, 2012 at 08:43 PM. Reason: put an icon for message!
How does the engine run under load, [driving] and when RPMs are up?
How does WOT feel.
Any smoke at any time, [idling, accelerating, decelerating, warm/cold engine], if so, what color? 94
How does WOT feel.
no smoke what so ever, honestley the engine runs legit. couple of small/minor back fires, but nothing too serious. sorry about this but what does "WOT" mean? lol i am new to this honda/acura circle, but willing to learn alot!
engine check like is on, different topic...how do i get the DTC for an ODB0? i am guessing if i learn on how to get the engine codes, i can fix all the problems.
suggestions? please let me know... thanks to you both
but yes please let me know on how to fix issue.
if it helps, i played with the air idle screw to increase/decrease the air! Am i wrong to do that? i made it to where it idle a 900, but on occassions idle still drops down to 500 to 700 and sometimes 1500. wierd idle play is irritating, smh!
ok thanks and that is good to know, all i know is headers and an ebay muffler which was baught like that! cold air intake.
When you adjust the idle with the screw the engine must be at op temp, the IACV must be unplugged, adjust the screw till rpm is at 750rpm or whatever you want it at, reconnect IACV connector shut engine off. To clear CEL for unplugging IACV remove the BACK-UP 7.5a fuse in the underhood fuse box for 10 seconds. Restart engine and see if the idle is better, if not repeat procedures above.
__________________
thanks for info, i am going to try out and ill be back on to let you know if it works! good looking out bro, i appreciate it!
ok now where can i find out what each blink or what codes mean? thanks
Last edited by DAmunster671; Oct 22, 2012 at 01:03 PM. Reason: forgot to ask another question!
