1991 integra rs timing
Old Oct 19, 2012 | 01:58 PM
dailyddriver's Avatar
Default 1991 integra rs timing
Looking for help. I put new timing belt on and every time I set the cams pointing up,put the belt on rotated counter clockwise two full revolutions then to TDC the up stamp on cams were off to left of center. So after 2 hrs of the same thing happening and not able to get it correct, here I am looking for advice. Thanks to all
Old Oct 19, 2012 | 02:48 PM
kchungb17a's Avatar
Default Re: 1991 integra rs timing
There are 2 timing marks on the cam pulleys at 3 and 9 o'clock with the "up" pointing up. They are on both sides of the pulleys. You need to line those up with the top surface of the head.
If your spark plugs are still in, try taking them out. It will make everything easier to turn.
You are loosening and re-tightening the t-belt tensioner bolt before you turn the engine, yes?
Old Oct 19, 2012 | 04:07 PM
I could not find any marks on cams other than the up, and I looked . I leveled them best I could then tightened the tensioner bolt and it runs smooth just feels like it wants to miss and it's not do zippy
Old Oct 19, 2012 | 09:23 PM
83rolla's Avatar
set the cams gears n tdc n behind the cam gear on the actuall cam theres a whole on each cam stick a allen key so that way it dont move i did that a few months back to my da9 me n my boys 1st time doing a timing belt we did that like 3 times till we got it right n even tho with the allen keys inside the cam they still move a lil tiny bit so have extra help to hold them down with a 12mm key or 14mm i forgot witch ne it is lol
Old Oct 19, 2012 | 10:35 PM
kchungb17a's Avatar
The marks are just little cuts in the pulleys. Do you have OEM pulleys? I stole this photo from the internets.
coltonbarrier
Feb 17, 2014 07:41 AM
wangan_DA9
Nov 1, 2004 06:39 PM
ITRfaithful
Oct 28, 2003 09:58 PM
PhazedSI
Sep 19, 2003 06:54 AM
216.226.142.95:27016
Jun 5, 2003 11:18 AM
