Stumped.... Code 9
Old Oct 17, 2012 | 01:18 PM
Bubbagump's Avatar
Default Stumped.... Code 9
Hello i have a 92 eg hatch with a ls turbo swap in it. i recently got it finshed and i had a check engine for code 9 the cyp sensor. So i did some research and ohmed out all the plugs on the distributor and they all checked out at 380ohms. So then i tried a diffrent dizzy for fun still check engine tried 2 others and still a check engine. Then i also tried 3 other good chipped ecu's and still nothing. Also replaced the wireing from the ecu to distributor and still had a check engine..... So i am runing out of ideas to try if anyone had any other thoughts that would be apprecheated thanks.
Old Oct 17, 2012 | 03:30 PM
ennah's Avatar
Default Re: Stumped.... Code 9
Did you try a different jumper harness?
Old Oct 17, 2012 | 06:08 PM
Bubbagump's Avatar
What do u mean by jumper harness?? its all obd1
Old Oct 17, 2012 | 06:26 PM
JuicedUpRice's Avatar
adjust your valves
90-91
intake - 0.006 to 0.007 inch
exhaust - 0.007 to 0.008 in
92-93
non-vtec intake 0.003 to 0.005 in
non-vtec exhaust 0.006 to 0.008 in
read here
http://forums.g2ic.com/showthread.ph...de-9-D-I-Y-fix
and make sure your timing is dead nuts on time.
Old Oct 18, 2012 | 03:47 AM
Bubbagump's Avatar
Ok......n but what does adjusting your valves do for a code 9?
Old Oct 18, 2012 | 05:13 AM
surfingsk8r's Avatar
Are you using an aftermarket distributor? I have seen many aftermarket distributors throw this code for no real explainable reason. I have also seen where the sensors ohm-ed out correctly but gave a weak signal (seen through an oscilloscope). If you were to find a way to move the pickup closer (read thousands of an inch) that would increase the signal strength and might solve your problem but I would try an known good OEM dizzy first and if that doesn't work I would check your wiring again and also make sure its shielded. Hope this helps.
Old Oct 18, 2012 | 09:05 AM
if your timing was off,it would effect when your distributor is firing.
Old Oct 18, 2012 | 10:29 AM
Adjusting valves does NOT affect mechanical timing and likewise electrical timing.
Old Oct 18, 2012 | 02:04 PM
Bubbagump's Avatar
Thanks for the responces guys i tried useing 3 other good dizzys i got a 4 day weekend so i will try goin over other things and mechanical timing is right i checked that many times. But open to any other ideas u guys may have.
stopltracr
Jan 25, 2016 04:35 PM
Knowski23
Oct 31, 2013 09:43 PM
NipponRacing
Jun 18, 2002 05:49 PM
rca90gsx
Apr 10, 2002 10:53 PM
