1994 Civic Lx starting/ running issues
Old Oct 16, 2012 | 05:04 AM
delmo777's Avatar
Default 1994 Civic Lx starting/ running issues
ok have an automatic 1994 civic lx, issues are runs good for a while well now sometimes will crank but not turn over. Will let it sit and then it will finally start. After driving for a bit the check engine light will come on and sometimes car will just die while in motion, put it in park then it will crank back up drive a bit and do it again. Any suggestions would be greatly appreciated as this is the vehicle my wife drives daily about an hour one way.
Old Oct 16, 2012 | 07:52 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 1994 Civic Lx starting/ running issues
Check the CEL code.
Old Oct 16, 2012 | 04:45 PM
delmo777's Avatar
Well the cel wasn't on when my wife got home, tried to check the obdI code, and the car started and ran fine, which is the main probem. It will run fine for a long time won't crank or cut off whie driving, I just don't get what's wrong.
Old Oct 16, 2012 | 04:48 PM
delmo777's Avatar
There was no code came on without cel lighting up at al
Old Oct 17, 2012 | 03:30 AM
NVturbo's Avatar
O.G. triple O.G.
If the CEL doesn't stay on all the time, more than likely it's either a bad ECU or faulty wire.
crxowner
Oct 12, 2011 02:54 PM
drkstrs24
23
Aug 19, 2010 01:09 PM
1sikhatch
Jan 31, 2010 09:06 AM
slowpokecivic
10
Mar 9, 2006 02:23 PM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
