CEL came on then car died
CEL came on then car died. More to the story now. Please read. Need help
I have a b18b1. So I was driving my car home and the CEL came on and the motor cut off. I tried starting it up and it just wants to crank and not start. I tried to check the code but it just gives me a solid CEL. Last week the CEL came on and it was giving me a code for the Cylinder Sensor then it went off. You guys think the distributor could have gone bad? I also tried pushing and popping the clutch and that didn't work either. Any thoughts and ideas would be great. I also changed the plugs and wires last week. Not sure if that would have anything to do with it
Re: CEL came on then car died
yeah. im going to see what i can do tomorrow. just seemed odd that it cranks but won't start and that i can't even pop the clutch to start it
I'm not positive, but if you've got everything setup correctly to pull the codes, and you're not getting any; it's likely the ecu is fried. But I would check all the ecu connectors and main engine harness connectors to be sure.
i will do that tomorrow. you think water could have anything to do with it? It has been raining and i am pretty low. i try to avoid puddles when possible and if i can't i go slow
Pull a plug wire off a spark plug and lay it on the valve cover where you can see it from inside the car. Crank the engine over and see if you have spark arcing from said plug wire.
if its an EG
check fuse #24 (ACG)
mine blows and throws a solid cel cause i have a exposed fuel pump wire and it gets grounded and blows it
and for anyone wondering, a solid cel (even when jumped) is Code = 0 (ecu)
edit: thx for the correction ron
Thanks guys. Im going to check all that out. Yes, I have the b18b1 in a 93 EG8. I got the car swapped an have been slowly fixing things the previous owner either started and didn't finish or just halfassed
So I went to check my car. Started right up and no CEL. I just wanted to make sure this wasn't a fluke. Checked for a CEL and now its showing 13 BARO - atmospheric pressure sensor. What could possibly cause this?
Misinformation here. When the jumper harness is jumped and your cel stays solid you have no codes, and it also confirms its in diagnostics mode so you can now adjust ignition timing when it needs it.
well, now the CEL isn't on and when i check it i get code 13. the car starts but im not sure if i should be driving with that code.
Technical Hero
According to the factory service manual for code 13:
1. Do the ECU reset procedure. Take out 7.5AMP BACK UP fuse from the under hood fuse box for 10 seconds. (Make sure you have the radio code before hand if you are using the factory radio as this will reset it). Replace fuse.
2. Recheck for code. If code is still there try a known working ECU. If code goes away your ECU is bad.
Thanks. I will try this. Do you happen to know what kind of affect this would have on the motor if i was to drive it since it starts?
Pulled the back up fuse and replaced it. Rechecked for code and its gone. I'm stumped. So do i have a bad ECU? Because this (2. Recheck for code. If code is still there try a known working ECU. If code goes away your ECU is bad.) confuses me.
ok. thanks. anyclue that would make that code show up? sorry if im asking allot of questions. just like to know whats going on with my car so if it happens again i have the knowledge
slowesteg
05-11-2012 11:07 PM
CornFlake340
07-24-2005 04:09 PM
slackeR1366
05-06-2002 12:48 PM
