cooling issues
Old Oct 14, 2012 | 08:20 PM
chrispcritter92's Avatar
Default cooling issues
I got a 92 civic with some cooling issues. I've replaced the thermostat and radiator and water pump appears to be fine. It still over heats and when going down the interstate at about 70 mph the transmission fluid starts to boil out. What else do I need to check? Could for some reason the coolant lines be clogged somewhere? If so, how do you check or even get it unclogged?
Thanks!
Old Oct 15, 2012 | 03:07 AM
grumblemarc's Avatar
The Grumpiest
Default Re: cooling issues
Transmission fluid boils out? Doubtful. You sure you aren't talking about the overflow reservoir for the coolant? Because if not you got more serious problems than overheating.
In all reality you might just have air trapped in the loop. Bleed it off. Don't continue to drive in an overheated state. You can/will ruin your engine.
Old Oct 15, 2012 | 03:55 AM
redm3turbo's Avatar
^ this
are you sure you mean trans fluid? how would you know its boiling? did you pull off a line going into the radiator and check it? or did a line down there pop? if it did all trans fluid would have poured out.
you probably have air in the system or you need a hg job. hows your oil look?
two ways to kill a honda, one of them is run it hot....fix whatever it is now, or youll be askin about how to change a motor.
Old Oct 15, 2012 | 04:21 AM
villc713's Avatar
Probably a bad HEadGasket and possibly fan not turning on.
Myechtatel
Honda CR-V & Element
May 2, 2014 06:09 AM
ck123
Jul 21, 2006 08:33 PM
mrx
Jun 18, 2006 10:21 AM
civicmatt
13
Sep 25, 2003 11:40 AM
integrx
Aug 29, 2002 01:07 AM
