ls vtec idel trouble
Old Oct 14, 2012 | 02:54 PM
chickenhawk44's Avatar
Default ls vtec idel trouble
so i have a crx with a ls vetc in it, i can drive to work under 60mph and the idle is fine, but when i get on the highway or im messing around it jumps from 1000-2000 rpm until i shut it off and then its fine, please help
Old Oct 14, 2012 | 03:31 PM
jeffkong11's Avatar
Default Re: ls vtec idel trouble
try checking the IACV valve and cleaning it with carb cleaner. or check for vacuum leaks
Old Oct 15, 2012 | 01:37 AM
eamonn's Avatar
Iacv valve gets full of dirt and carbon take it out and clean and hopfully thats the problem
Old Oct 15, 2012 | 11:41 AM
civickiller's Avatar
make sure no air in cooling system and fitv is screwed in if cleaning iacv doesnt work
Old Oct 16, 2012 | 04:25 PM
ok so i cleaned my iacv and after do that my car would not idel for nothin, enery time i pushed in the clutch it would die, and for some reason the check engine light came on, and also when it is driving if i have the gas barely on it acts like it want to die to, please help!
Old Oct 17, 2012 | 05:44 AM
kyden's Avatar
pull the code.
Old Oct 17, 2012 | 07:35 PM
i thought you could just hook a code reader up to but nope lol, then i figured out there is "supposed" to be a red led on my ECU but theres not, so how to i check it from this point. sorry for these stupid questions just new to hondas
Old Oct 17, 2012 | 07:37 PM
it has a thermal zero ECU in it
Old Oct 18, 2012 | 06:13 AM
kyden's Avatar
is it obd1?
Old Oct 18, 2012 | 06:41 AM
no obd2 it has a p28, or does it matter?
HdmPowered
Jun 3, 2010 09:57 PM
TurboHayabusa
Jun 18, 2007 05:57 PM
csudhoff
Feb 16, 2007 08:24 PM
1.8 tuner
May 23, 2006 07:25 PM
aacosta6
Jan 3, 2002 07:07 PM
