starter and ignition not "talking"
Old Oct 14, 2012 | 10:44 AM
95civicproject's Avatar
Default starter and ignition not "talking"
i replaced my battery to days ago went on base drove around a bit. killed it (left it in third with an aftermarket clutch oops) haha started it back up. drove to the base exchange went inside came back out turn the key and nothing. no clue this is the second day straight that i have been working on it i replaced the starter i guess my old one was working so that didnt fix it. everything is hooked up right cleaned the battery terminals and re did all the grounds (tranny and motor) just in case nothing any ideas ? i was able to push start it and drive it home. i just cant figure out why when i turn the key it turns all my dash lights on and all that shoots power to the correct wire but somewhere in the tangle of wires under my dash its charge gets lost before it makes it through the firewall i just dont understand how it happened so suddenly it just works one second and DONE the next.
1995 Honda Civic Ex
Mini me swap d16z6 with y8 head
replaced battery two days ago.
starter good
battery charged
got jumped nothing
fuses are good (unless there is another one besides the one by the driver's knee)
^^^i think that is all the info i have that you need for now at least.
thx
Old Oct 14, 2012 | 11:06 AM
ozh_hawaiian's Avatar
Default Re: starter and ignition not "talking"
does it turn over at all, or do you just get a "click"? start by checking check all your grounds and fuses
Old Oct 16, 2012 | 11:22 AM
It did nothing just basically looks like I clicked it over to on II you know like I want to listen to music or roll up the windows no click no nothing all fuses were good but I SOMEHOW. Fixed just was confused so I hooked up everything how it was and it turned over and started would still like to know the problem in case it ever presents itself again
Old Oct 16, 2012 | 11:31 AM
mayfly's Avatar
check your clutch saftey switch
Old Oct 16, 2012 | 11:32 AM
mayfly's Avatar
are you pushing the clutch all the way to the floor?
sounds dumb but it happens
Old Oct 16, 2012 | 12:13 PM
angrysmileyface's Avatar
Are there little pieces of plastic lying in the foot well that look like blue or white crayon? If so, then its your Clutch Safety switch. (costs like 4 bucks at the dealer to get a new stopper)
uNF$@#!
Jan 8, 2021 08:31 PM
MID0RI
Apr 17, 2009 06:35 PM
BrothaSit
Aug 14, 2006 01:21 PM
Heavy Pee
Jul 21, 2003 08:32 PM
carl_aka_carlos
Jul 24, 2002 03:36 PM
