HELP!! engine codes
Old Oct 13, 2012 | 07:41 AM
eg6_vti93's Avatar
Icon6 HELP!! engine codes
i've had these engine codes come up on my 1993 civic eg6 b16a2, code 9 (cyp) 8 (tdc) 15 (ignition output) i have just fitted a new distriutor but still have the problems is there anything else i can do?? i also have a code 1 (oxygen sensor) and 43 (fuel supply system) any help would be great as im stuck with wat to do thanks
Old Oct 13, 2012 | 11:21 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: HELP!! engine codes
For 9, 8 and 15 you need to check the wiring going to your distributor, sounds like you may have a short. Also check the wiring going to your oxygen sensor as well. What ECU are you using? Take some pics of your distributor and O2 wiring to determine what to do next.
Old Oct 13, 2012 | 12:58 PM
eg6_vti93's Avatar
not sure on ecu i'm assuming its standard? thanks for the in put and i shall check it all over
Old Oct 14, 2012 | 01:13 AM
eg6_vti93's Avatar
can't seem to find any loose connections and also would these problems cause the car to run flat and have power loss its like driving a 1.4 non vtec???
Old Oct 14, 2012 | 04:49 AM
Technical Hero
Reset the ECU by pulling the 7.5A backup fuse in the underhood fuse box for 3 minutes to clear your codes and see which ones come back and we can start from there.
Old Oct 14, 2012 | 06:14 AM
eg6_vti93's Avatar
i've reset the ecu and code 9 has come back the rest haven't??
oldschoolfreak
Mar 25, 2005 06:18 PM
TorinRage
Jan 27, 2005 11:26 PM
jfteg
Oct 28, 2003 11:59 AM
Nerv2g
Aug 10, 2003 08:42 PM
type Gendy
Jul 31, 2003 07:31 PM
