Check Engine Code 9
Old Oct 28, 2003 | 11:22 AM
jfteg's Avatar
Default Check Engine Code 9
Everybody told me that was a distributor problem. I change it and the check engine came back again. Do we have to make a reset on the ECU with a scanner??? I make a reset (unplug the batterie) when I install my new distributor, but the code came back 2 days after. I got a integra RS 99.
Old Oct 28, 2003 | 11:35 AM
JimBlake's Avatar
Default Re: Check Engine Code 9 (jfteg)
Code 9 is the #1 cylinder position sensor, in the distributor. But maybe the problem was originally caused by flaky wiring back to the ECM? I always like to check the wiring out before I replace parts...
Old Oct 28, 2003 | 11:41 AM
jfteg's Avatar
I know that I install a air/fuel gauge in my car a few week ago, maybe it's a trouble a the ECU with the cable that I had there......
Old Oct 28, 2003 | 11:59 AM
JimBlake's Avatar
Shouldn't be related to that, unless you messed up the CYP sensor wiring when you did it...
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
stopltracr
Jan 25, 2016 04:35 PM
sh!ft
Oct 10, 2012 08:57 PM
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
jedb18
May 31, 2008 12:32 PM
