tranny issues first n second never want to go in..
Old Oct 3, 2012 | 07:49 PM
ricky tan's Avatar
Post tranny issues first n second never want to go in..
What's up HT. I've been having this problem wit my Tranny for a bit now. After breaking diffs, Couter shaft, and 2nd gr at different times now that its all together for the fourth time I'm still having trouble getting it in to1st n 2nd especially when i come to stops n red lights. Ive changed 1st n 2nd gr syncro twice. Completelycleaned it out. Replaced the counter shaft bearing that sits in the bell housing do to the counter shaft wearing it out for some reason and last thing i just did was juts bout a new linkage from has port n still doing the same Is there anything else i should check b4 i go get a new tranny?
Old Oct 3, 2012 | 08:14 PM
turbociv910's Avatar
Default Re: tranny issues first n second never want to go in..
after all that and no changes id suspect a bent fork?
mine wouldnt go in third before the dogbox and same thing after i installed it, put a solid joing in my linkage and fixed it, assumed it was bent or highly worn out.
Old Oct 3, 2012 | 08:19 PM
tepid1's Avatar
or a bad SCHA
Old Oct 3, 2012 | 09:14 PM
2fast4u831's Avatar
I'm really 2slow
Did you also change the 1st/2nd synchro sleeve set? Could also be a bent shift fork.
Old Oct 3, 2012 | 10:26 PM
FarmYard's Avatar
http://www.speedfactoryracing.net/st...roduct=1650787
Old Oct 4, 2012 | 01:41 AM
ricky tan's Avatar
Post Re: tranny issues first n second never want to go in..
It started in my gsr tranny then i switched the gearing to a LS n it's doing the same thing.
Old Oct 4, 2012 | 01:45 AM
ricky tan's Avatar
I even changed the clutch master n slave. I thought it could be the clutch ( exedy twin disc) but the tranns still doesnt want to go into 1st or 2nd even when the car is off..
Old Oct 4, 2012 | 02:05 AM
d15Beta's Avatar
this is of no help.. but i do hope these seasoned guys can steer you into the right direction as far as ur trans woes (wobley/bent and straightend linkage possibly?)
as for myself.. i wonder.. are you the bad guy in RushHour 2 ? the one who owns the red dragon boat? LOL!
Old Oct 4, 2012 | 03:23 AM
BILLY_BAD_A$$'s Avatar
My money is on the fork for 1st and 2nd. I just went through something similar. Good luck
Old Oct 4, 2012 | 05:36 AM
MR.johnson's Avatar
Post up some pics of the sca and gear stack.
Old Oct 4, 2012 | 05:55 PM
ricky tan's Avatar
I will post pic s up tomorrow
Old Oct 4, 2012 | 06:06 PM
ricky tan's Avatar
Dont think is the shift forks because it was doing the same wit the gsr gearing i had. The only thing that's the same is that SCA piece.
Old Oct 5, 2012 | 12:18 AM
tepid1's Avatar
If you kept the same forks it could....
It's either the SCHA or the forks. It's that simple, especially if you're using an OEM based shifter assembly.
Old Oct 5, 2012 | 06:04 AM
cloviskilla's Avatar
I had that issue and it was my cheezy carbon synchros. The synchro sleeve was digging into the thick notches on the outside of the synchro. I put in a stock synchro and never had the issue again. I was having to start the car in gear etc.
Old Oct 5, 2012 | 07:57 AM
VTC#2's Avatar
also check your pilot bearing...i had one go bad and made going into second gear at high rpm hard.
snatch
Jun 9, 2004 07:52 PM
reeder321
Apr 21, 2004 02:44 PM
ActiveAero
Apr 14, 2004 07:44 AM
VTEC-DA
Apr 3, 2003 06:15 PM
B18C5-EH2
Nov 13, 2001 01:59 PM
