1990 Civic Hatchback- Brake Light issue
Old Oct 1, 2012 | 10:26 PM
David Bromberg's Avatar
Default 1990 Civic Hatchback- Brake Light issue
Hi there,
So my right brake lights are out- completely. I went out and bought the lights and got ready to install them, but had a lot of trouble figuring out which light to replace. I turned on my headlights, and it appeared that what I thought were brake lights were also tail lights, and were working fine... at least as tail lights. When I hit the brakes, they don't come on, only on the right side. They are two filament bulbs- does it use one filament for each purpose? Or is there a connection issue? Or have I just not found which light is the brake light? Where should I look next? Any help would be appreciated.
-David
Old Oct 1, 2012 | 10:47 PM
~sp33~'s Avatar
EFB055
Default Re: 1990 Civic Hatchback- Brake Light issue
It's a dual filament globe, and only one filament has broken. Hence why the tail light is working, but your brake light is not.
Replace the bulb and it'll be fine.
Old Oct 2, 2012 | 09:41 AM
civic4life8045's Avatar
check your fuse box under the hood and look at the horn/stop fuse
enemy no1
Feb 17, 2014 04:31 PM
tgun08
Apr 1, 2008 07:28 AM
AndyD
Feb 18, 2008 11:09 PM
Importn2oRacer
Aug 7, 2007 12:17 PM
Draggin99Si
Aug 23, 2004 06:59 PM
