The significants of Cam gear Adjustment When it comes to Forced Induction.
Im currently running h22a +Jrsc in a prelude, with rc440cc injectors+255walboro fuel pump....Im working with the p5p oem computer right now because i missed inspection and on way to passing..and was wondering if adjusting my cam gears to -.o5dgz exhaust and +3dgz Intake would be a good setup for the old Twin screw. No easy access to Dyno tunning
http://images.ibsrv.net/ibsrv/res/sr...s/emcocktl.gif
heres an idea of how cam timing can effect you
even on a SOHC, we had the cam out by 4.7 degrees. on 35psi it trapped 130mph
we corrected the timing, car ran 129mph on 19psi.
You need to be careful seperating cams really far apart like that on a DOHC. You can run the valves into each other. There are dynos around if you're interested.
I'm very interested in dyno tuning, The closest place i know of that specializes in honda/acura is Innovative Motor works, But their all the way down in Carlisle PA so it requires a lot of planning around work. I'm searching for the Cam Gear ratios for my setup to reduce emissions, because i missed inspection in July; I've ben pushing a D16y8 to save gas cash for the full tune.
I have a OBD1 Computer with a jumper harness base mapped for my setup and Want to get that tuned instead of my OBD2 P5p, I'm still in 2012inspection so i want to get a new sticker on my car before i do the final tune. Cam gear adjustment with help
Im Reading of people Running JSRC on Bseries At .25*exhaust retard and 4* Intake advance pushing 8psi...But i dont think i would want somthing that spread because H Series are completely different engines, and it sounds a bit drastic.
It depends entirely on the cam you are using and the LSA of the set whether or not they need to be spaced out or not on a forced induction car. People have good luck with NA cams because they can dial out some of the overlap associated with the NA cam using the adjustable gears.
Who is Mr Robot?
without a degree wheel and knowing the cam's exact specs, its pretty pointless.
What cams r u running. Aftermarket cams have presets usually to start at. Correct me if I'm wrong but cam timing varies a bit on supercharged turbocharged and NA. Plus cam tuning will never be the same from car to car.
How many times can you contradict yourself in a 4 sentence paragraph?
Or get on rt 17 and take the trip down to xenocron. Cam gear adjustments really need to be done on a dyno
For reference I picked up between 10 and 15 hp messing with cam gear settings on a 400hp setup.
Alright i need a dyno tune pointblank. Making the neccisary arangments then getting this car taken care of
bigsnorlax
Apr 20, 2009 09:18 AM
stevethefishguy
15
Aug 30, 2006 06:53 PM
rtiadnoh
Mar 16, 2004 07:24 AM
Speed PHreak
Feb 4, 2002 04:51 AM
