problem wih ek 96-98 coupe fog lights
Old Oct 1, 2012 | 05:23 PM
MGBej1503's Avatar
Icon2 problem wih ek 96-98 coupe fog lights
I installed a pair of Ek fogs and they work great while the bumper is on the ground and the wires atre pulled straight. But as soon as I put the bumper up to my car the fuse blows. I can't figure this **** out what is causing this fuse to blow. I tried covering up.all the wires but I haven't put electrical.tape around them yet just normal tape. Any ideas? I've searched but nothing with this specific problem? Any he'll much appriciated
Old Oct 1, 2012 | 05:52 PM
MGBej1503's Avatar
Default Re: problem wih ek 96-98 coupe fog lights
Or what I can I do.to make it stop frying my fuses??
Old Oct 1, 2012 | 05:54 PM
Yoitshector's Avatar
A wire is touching causing it to short out and blow your fuse look for a naked wire either touching anything metal or another wire
Old Oct 1, 2012 | 05:59 PM
MGBej1503's Avatar
Like would it need to be a bare wire or even one with the skin around it touching another with the skin around it? So should I just use electricaltape and tape each wire separately and completely?
Old Oct 1, 2012 | 06:05 PM
furious94ls's Avatar
Wrap the wires correctly. Ideally you want to sodder it.
Old Oct 1, 2012 | 06:37 PM
MGBej1503's Avatar
Ok.I.will look glfor pinched wires or a bare wire touching another
Old Oct 1, 2012 | 09:13 PM
Cap'N Chronic's Avatar
What are they grounded on?
Old Oct 2, 2012 | 06:55 AM
MGBej1503's Avatar
If they were grounded wrong wouldn't it blow as soon as they turn on every time? They work fine until the bumper meets my core supporrt
Old Oct 2, 2012 | 07:19 AM
kyden's Avatar
please tell me you at least used crimp connectors and didn't just twist the wires together.
Old Oct 2, 2012 | 07:49 PM
Could be moving the ground wire around as you put the bumper on, but more than likely it's a bare wire contacting somewhere. What kind of kit did you get?
wtemale
Nov 18, 2017 05:08 PM
92integraVTECgsr
15
Nov 7, 2006 10:55 AM
tgctruly
Nov 8, 2004 12:12 PM
Chris y0!
Mar 22, 2003 08:30 PM
HatchBox
13
Aug 7, 2002 10:40 AM
