93 honda auto to manual swap trouble
Old Sep 29, 2012 | 04:58 PM
cloud4571's Avatar
Default 93 honda auto to manual swap trouble
93 civic auto to manual swap -
thanks so much for your help before. but i ran into another problem. it wont start, .Everythings getting power. i haven't tried jumping the starter. because the key wont come out. so i think its some kind of relay from the auto transmission lock that wont let you take the key out, unless its in park. whould that have anything to do with it not giveing power to the starter
Old Sep 29, 2012 | 05:00 PM
cloud4571's Avatar
Default auto to manual swap car wont turn over
Finished swap to a manual on1993 honda ex. I put in a 1.5 with a manual tranny.
My problem is the car won't turn over I'm assumeing I need to splice a wire together
Because I can't take the key back out without disconnecting the battery I think the car thinks its in gear or something
Old Sep 29, 2012 | 05:07 PM
dns92civhatchcx's Avatar
Default Re: auto to manual swap car wont turn over
clutch is not pushed in all the way or clutch is stuck other than tht idk why it wouldnt start
Old Sep 29, 2012 | 05:12 PM
cloud4571's Avatar
The sensor for that wasn't even on the manual car that I pulled the motor out of what do I do to bypass that
Old Sep 29, 2012 | 05:17 PM
yes you could use same harness from the car you got it from if your using the a/t harness then thts the prob right there
Old Sep 29, 2012 | 05:26 PM
cloud4571's Avatar
Well that's a lot um can I make the car think its in park by spliceing some wires. Kinda running short on time
Old Sep 29, 2012 | 05:49 PM
Former User's Avatar
Did you remove the interlock control unit?
Old Sep 29, 2012 | 05:51 PM
cloud4571's Avatar
Well sence I have no idea what that is no. where is it located and what dose it look like? Thank you all very much for the reponce so far
Old Sep 29, 2012 | 05:56 PM
97civkid's Avatar
Default Re: 93 honda auto to manual swap trouble
When u took the auto shifter apart, what did you do with the wiring?
Old Sep 29, 2012 | 06:01 PM
Only one thread per topic is allowed. Related threads merged.
Old Sep 29, 2012 | 06:04 PM
97civkid's Avatar
Wire the 2 thick black wires, that should let you start it, the on the steering colum remove any plastic covers and there should be a little white box with a screw holding it shut, take the screw out and a pin should either fall out on its own of you will have to pull it out with a flat head, that will let you take ur key out
Old Sep 29, 2012 | 06:37 PM
vitamin_c95's Avatar
both of these. Either wire the two thick wires together at the auto shifter, or plug the neutral safety switch back in and move the slider to were the computer will let engine start (thinking its in park, then secure it in place)
Old Sep 29, 2012 | 08:13 PM
cloud4571's Avatar
Wow I just wanna say you guys are the best its late so I'm gonna try in the morning.
Sorry about the other topic I asked my friend for help and he posted the other one
Old Sep 29, 2012 | 08:25 PM
Luserkid's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
Exact same principle just newer chassis. Pics and all
Old Oct 1, 2012 | 07:57 AM
cloud4571's Avatar
Originally Posted by Luserkid
https://honda-tech.com/forums/showthread.php?t=1337459
yea i read some of that that helped a lot that's how i found out i needed a different mount for the tranny
Old Oct 1, 2012 | 07:58 AM
cloud4571's Avatar
ok i have it running but now the engine is moving up and down when I'm driving, the thread that Luserkid posted said to use the auto axles. i used the manual ones my only thing is the manual one driver side is shorter and went in fine. i didnt check the size of the passenger side one but they looked the same. will swapping them fix it or are they the same size
(edit) ok i looked online im pretty sure there the same size any idea what i would have done wrong to cause this the passenger side is also sitting kinda higher
(edit) when were putting the motor back in the passenger cv axle dug into the ground as we where lowering the engine in if a joint popped out or we bent it could that be causing this. its not knocking tho
Old Oct 1, 2012 | 08:35 AM
kyden's Avatar
do you have the auto to manual conversion mount?
Old Oct 1, 2012 | 08:52 AM
cloud4571's Avatar
yup i ordered it off ebay this is it http://outboundlink.me/ib.php?DR_id=...3Fp%3D47891337
i couldn't get it to mount with the other one. Is it possible that it is angled wrong dont think thats possible but you never know
also i used the rear mount from the manual the driver side mount from the auto busted the manual one when putting the engine back in and that conversion one i got off ebay
i drove the car down the street everything is in it just has one hell of a pull and the thing where the engine picks up and the car kinda drives funny
Old Aug 3, 2013 | 06:45 PM
SEKTORMYNE's Avatar
I am doing a transmission swap on my 93 delsol 1.5L and trying to find out what else I need but the site wont let me upload the photos I have taken. If anyone may help I can e-mail you the photos to see what else I need
Old Aug 3, 2013 | 07:06 PM
Upload your pics to ImageShack, PhotoBucket, etc. Then paste the image links into your post.
EFJDM1
Sep 6, 2017 03:05 AM
TheDonOG
Jan 1, 2017 01:25 PM
tony n.
Honda Civic (2001 - 2005)
Jan 6, 2010 12:46 PM
HondaIsBueno
10
Apr 14, 2008 08:14 PM
