Is vac necessary on a boost gague??
Old Oct 17, 2002 | 08:37 AM
fire7882's Avatar
Default Is vac necessary on a boost gague??
I have a boost gauge laying around without the vac. it only reads boost up to 15 psi. I like it better than the ones that read vacume because it is easier to read. Is the vacume reading necessary or will this gauge be ok.
Old Oct 17, 2002 | 08:45 AM
inspyral's Avatar
Default Re: Is vac necessary on a boost gague?? (fire7882)
It's nice to know your vac reading at idle, in case you have a vac leak or something.
Old Oct 17, 2002 | 10:35 AM
Etylorcen's Avatar
Default Re: Is vac necessary on a boost gague?? (inspyral)
But it is better than nothing.
Old Oct 17, 2002 | 10:41 AM
tmg's Avatar
tmg
especially if you boost really high and you need to do a systems check.
Old Oct 17, 2002 | 04:27 PM
MikeMAN's Avatar
Default Re: Is vac necessary on a boost gague?? (themi6group)
yuppers. i guess, it would depend on how advanced ur setup is, if its just a junkyard turbo , that would be more than enough..but it would be nice to have -vac readings so you can check for leaks!
nzrnk
Apr 5, 2005 04:40 AM
turbonitrousgsr
Oct 6, 2003 06:54 AM
JDM_EH2
Sep 18, 2003 09:10 AM
CRVRX
Nov 16, 2002 08:03 PM
b18tdelsol
May 18, 2002 11:46 AM
