Car wont rev pass 5k!! help.
Old Sep 26, 2012 | 10:51 PM
ever'sneighborhood's Avatar
Default Car wont rev pass 5k!! help.
ok i have a d15b2 with mpfi swap, wiring is good, I got no codes on the ecu, timing seems to be good, the car runs fine but then loses power like at 4500rpm then it stops at 5k, does anyone have any idea of what could it be? then when the car is fully warmed it misfires, specially like during the day when its hot, but at night when its a bit more cold it doesnt misfire, why is that?
Old Sep 27, 2012 | 03:41 AM
crvtectim's Avatar
Default Re: Car wont rev pass 5k!! help.
Do you still have a catalytic converter on the car?
Old Sep 27, 2012 | 07:02 AM
^no sir, no catalytic on the car
Old Sep 27, 2012 | 12:51 PM
neophish's Avatar
how is the fuel filter? i used to have a civic that had the same problem
Old Sep 27, 2012 | 02:40 PM
well its a new fuel filter, so in yours it was the fuel filter giving you problems?
Old Nov 13, 2012 | 08:12 PM
sohc_ef2's Avatar
if ur still having this issue... do u have a check engine light on?
Old Nov 13, 2012 | 08:41 PM
JuicedUpRice's Avatar
check your spark,sounds like a bad coil.
check resistance of the coil should read anywhere around .6 i believe.
or possibly an ecu problem.
i am having the same issues and it cuts out and backfires LOUD from the exhaust if i bring it to 5krpms,even lower sometimes..
but mine is because i fucked up a wire to the coil and havent fixed it yet..been workin on it all day..
jdm mini me
11
Mar 28, 2010 05:22 PM
hontoyo
Apr 18, 2009 05:30 PM
Jorsher
Feb 23, 2006 09:27 PM
Triv
Jun 3, 2004 07:24 AM
MeanGreenEG9
Mar 14, 2003 02:20 PM
