please help with my eg swap with a 99-00 si motor!!
I have a 92 civic dx hb and im trying to put a motor from a 99si into my car by honda part # it says i can use all my sohc motor mounts will this work or will i need motor mounts from a 94 integra??
negative. you need the SI Mount (bolt to block under cams) a si rear "T" bracket, and an aftermarket drivers side mount (innovative, hasport, or a cheap ebay one for now)
Use 94-01 Integra T bracket, 99-00 Si won't work. SOHC rubber mount portion with 94-01 Integra metal or DOHC VTEC Del Sol. You won't be able to plug and play the alternator, injectors or distributor. You'll either need to rewire or use adapters or use their OBD1 counterpart. 94-01 Integra shift linkage. Wire up VTEC and knock sensor. Use an OBD1 P30 ECU or P28 with a P30 basemap.
What he^ said. Just get the innovative or hasport mounts you'll end up with them anyway. Save yourself the head ache and just slap them in now.
99-00 SI bracket is needed in a 96-00 Civic because it uses a different subframe. The 94-01 Integra T bracket is longer because the 92-95 Civic and Integra sharer basically the same engine bay and subframe.
ANGELIQUE
Mar 15, 2005 12:25 PM
