93 Accord... Red and Black plug near Crank pulley
Old Sep 23, 2012 | 12:46 PM
DDream's Avatar
Default 93 Accord... Red and Black plug near Crank pulley
Been having problems with a h22a swapped accord
so i was going to check timing when i noticed a plug close to crank pulley not plugged in... i did a continuity test to some pins at the ecu and found it works with almost all the wires somehow
does anyone know what this plug goes to?
Old Sep 23, 2012 | 12:56 PM
lazlong's Avatar
Default Re: 93 Accord... Red and Black plug near Crank pulley
Only sensor I know of near the crank is the crankshaft position sensor (CKP).
Old Sep 23, 2012 | 01:02 PM
DDream's Avatar
well thank would make sense why its not running but i would have a CEL correct?
i thought that was in the dizzy
Old Sep 23, 2012 | 01:14 PM
lazlong's Avatar
Sorry, forgot your car was that old. Yes, it's in the dist. I have no idea what it is now.
Old Sep 23, 2012 | 01:19 PM
DDream's Avatar
hmmm i wonder wtf it is... it doesnt plug to secondary butterflys
Old Sep 23, 2012 | 01:32 PM
GhostAccord's Avatar
What year is your H22?
If it is an OBD2 H22A4 and there are 4 wires that would be the TDC and CKP sensors. You will need them or an OBD1 distributor with those sensors in it to get your car running.
Old Sep 23, 2012 | 01:37 PM
DDream's Avatar
this is a buddies so i dont know exactly what it came from or anything really
but its stamped h22a supposedly a jdm model i looked closer and there was something plugged in... hold on a few minutes see if you know
Old Sep 23, 2012 | 01:43 PM
DDream's Avatar
never seen this before
Old Sep 23, 2012 | 03:11 PM
That looks like the connector part of a knock sensor. The rest if it is probably still screwed into the block up above the oil filter.
Old Sep 23, 2012 | 03:22 PM
DDream's Avatar
awesome... thanks bro
ill check that out... one more Q.is there any way that could cause the car to have problems running if disconnected?
Old Sep 23, 2012 | 03:41 PM
It will cause the ignition to go into a limited state. The engine will run poorly under load and higher RPM conditions. MPG will be lower and it will seem sluggish and may even start bucking at times as well.
Old Sep 23, 2012 | 03:55 PM
DDream's Avatar
well i found the knock sensor the only thing is that the thing i took a picture of did not plug in to it
not really sure
is that a knock sensor that was torn out?
Old Sep 23, 2012 | 04:18 PM
Yes..that green part is the broken connector portion of the knock sensor itself. Sorry, I should have been more clear in saying that it was a broken part and that the KS would require replacement.
butter99
Dec 30, 2008 10:58 PM
KING PIN
Apr 30, 2007 07:03 AM
blowbyu24
Jan 12, 2007 10:54 PM
93FastLs
Jun 4, 2005 12:43 PM
sweetcarz02
Dec 17, 2003 12:09 PM
