CKF sensor location?
Can someone post a pic where exactly the CKF (crankshaft speed flucation sensor) is, service manuel says in the middle of the engine but I am looking for exact location.
Thanks in advance
Thanks in advance
Former Moderator
Re: CKF sensor location? (sweetcarz02)
It is right by where the crank pulley slides onto the crankshaft. Theres a few wires and a mini harness with plug coming from it.
WHY do you ask though? You getting that code from a swap or something?
Down Since Day 1
Re: CKF sensor location? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">It is right by where the crank pulley slides onto the crankshaft. Theres a few wires and a mini harness with plug coming from it.
Fo Sho.
Fo Sho.
Re: CKF sensor location? (1 point 6)
The CKF is the Crank fluctuation sensor, not the crank speed sensor (CKP)
When I had this problem it turned out that the wires hade come out of the loom around the crank cover and got cut by the alternator belt.
I spliced them and everything was fine.
no the beastly turtle stop working 2day at wendy's and gave me a code 54. I am 2 lazy 2 dink with it so in the morning I am off 2 work with th tools. hopefully it just got cut, don't really ever hear of them going bad
