B18C1 REBUILD ISSUE
Old Sep 22, 2012 | 08:22 PM
oldskoolracer's Avatar
Default B18C1 REBUILD ISSUE
ok, car has been sitting for a while with a fresh rebuilt motor.
i tried to turn over and fogged the cylinders to be safe, no start.
i pulled compression and it's odd
from 0 psi 100psi 100psi 0 psi
just odd i tried to put some oil in the cylinders and let it work into the rings and turn over
open to get rest of the oil out and still the exact same any suggestions?
car has been sitting for well over a year in a climate controlled garage waiting to be put back together.
not sure if rings are stuck, or possibly valves are stuck etc.
Old Sep 22, 2012 | 10:18 PM
hybridmiklo's Avatar
Default Re: B18C1 REBUILD ISSUE
you check valve clearance?
Old Sep 23, 2012 | 06:05 AM
i pulled valve cover this morning and gotta find feeler gauge.
i dont remember the clearances, man i had to have car in storage for a while
and was not able to work on while in country so almost feel i have forgotten how to do it
its crazy i fell like i'm starting over
Old Sep 24, 2012 | 08:37 PM
Muckman's Avatar
Moderator in Chief
Cam timing needs to be off to produce those compression numbers. Check tbelt.
Jamarquis
Jul 3, 2008 11:33 AM
Bambin0
Nov 10, 2006 09:18 AM
mitsuman
21
Oct 4, 2006 08:50 PM
Slammed2K1
Dec 5, 2003 07:35 PM
gsr stuie
Apr 23, 2002 08:03 PM
