Vibration primarily under acceleration, play in left CV inner joint
Hey all, been a while. Search indicated that the driveshafts were the place to look, and I think I found the problem; there's about 1/8th inch of play in the inner portion of the left axle assembly when I wiggle the shaft; the right doesn't wobble the same way, and the intermediate shaft and bearing seem to be solid.
I assume any wiggle is a bad wiggle in this case? Gonna get my ducks in a row before I start pulling axles.
This is a general Honda issue. If you get vibrations while accelerating, it's almost always an axle. You can get away with replacing just the CV joint - but I'm lazy and like to replace the entire thing.
