need help code 7 throttle angle position
Old Sep 20, 2012 | 10:08 AM
StrokeDC2's Avatar
Default need help code 7 throttle angle position
im throwing a code 7 even after swaping out to a new tps, calibrated it correctly numerous times, trying to balance everything that has to do with the throttle body to iacv to bleeding coolant lines to anything i think would help but no...never goes away. Omg ive never stressed so much before on my car like this lol someone please help, im usually able to always fix my problems but this one is tricky.
https://honda-tech.com/forums/acura-integra-6/after-hitting-pothole-dip-rpm-drops-3089423/
Old Sep 20, 2012 | 04:19 PM
10psiLsEf2's Avatar
Default Re: need help code 7 throttle angle position
OK.
let me just ask a few questions.
can you even drive the car?
does it idle like ****?
if it idles like **** its a possibility that you may have crossed the map and tps sensor plugs. they are identical but different wires....
.5 closed 4.5 wot.
maybe its a faulty tps sensor but i cant help you much more since you didnt tell us if its running,not running,running like crap, etc.
Old Sep 20, 2012 | 04:22 PM
10psiLsEf2's Avatar
im sorry now that i actually saw and read the link.
uhmmm check for the connector make sure it snaps in on the sensor
look at the wires and make sure they are all snug, also look at the side of the connector and make sure that all the wires are showing. on the side of the connector thats the female side..
luck
Old Sep 20, 2012 | 05:50 PM
hybridmiklo's Avatar
How bout you go about this the right way. Check that there is 5volt reference and check that there is a good ground.
Pinarr
May 18, 2012 08:36 AM
ScottEK
Jun 12, 2006 06:02 AM
TegLove
Apr 23, 2004 11:24 AM
DRKSol
Apr 5, 2004 03:32 PM
RABBIT9
Jan 9, 2003 05:45 AM
