Need some experience help
Old Sep 17, 2012 | 09:54 PM
hybridmiklo's Avatar
Default Need some experience help
As title states, I need some guidance from some people with good knowledge. I have a 96 civic dx. Ran perfect. Swapped in a b20 vtec. Jumper harness to obd1 using a p28 ecu.
Car runs like doodoo, sputters at idle and delays when given gas.
There are no cels, I did the ckf trick and the iacv trick. Head fresh from machine shop. Block ran great before. Fuel pressure is perfect, compression is 150psi across. Mechanical timing is perfect, valve clearance in spec. The odd thing I found was that there was only 15hg vacuum to the map sensor. And when I give the map sensor 20hg vacuum from my vacuum pump the car idles and revs perfect. The map sensor gets 5volts and has good ground. And have swapped with a known good map sensor. I have almost empty tank of gas and there is 87octane in it. Any1 have any good suggestions or insight on this? Did I miss a trick for swapping in this model year?
Old Sep 17, 2012 | 10:51 PM
turbohatch96y7's Avatar
Default Re: Need some experience help
Is this a stock map sensor?
Is the map sensor on your throttle body?
Old Sep 17, 2012 | 10:55 PM
Have you checked the output voltage from the map AT the ecu?
Look for damaged pins on the jumper harness.
Looks like the problem is pin pointed at the map check all connections there and fix your vacume readings.
Old Sep 19, 2012 | 12:37 AM
dapimp1814's Avatar
Does your p28 have the mappings for b20vtec? If you have low mappings it causes that becuz when my boy put a b20 in his car he used a stock p28 and sounded like poop and then i told him to use a LS ecu and sounded perfect.
Old Sep 26, 2012 | 07:35 PM
Well don't know why but the y7 injectors for some reason are different than obd2 bseries injectors. Swapped them out for bseries and no longer a problem. Weird
Old Sep 30, 2012 | 03:24 PM
dapimp1814's Avatar
The y7 injectors are 190cc and b series have 240cc the p28 is programend for 240cc dats y their different dat explain y it acted that way.
Old Sep 30, 2012 | 06:52 PM
Really? I didn't know that. Thanks for the info!
Old Oct 1, 2012 | 06:48 AM
kyden's Avatar
just to note, the ckf trick is only for obd2 ecus. also, put 93 in the car.
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
allnaturalb16
Oct 19, 2007 10:14 PM
drycreekgsr
Aug 31, 2006 07:45 PM
Soichiro-son
Aug 19, 2005 06:35 AM
HondaCutter
Sep 23, 2002 09:41 AM
