96+LS to 92DX
I know that the 96+ LS motor is OBD-2 and my car is OBD-1, will I need to change any wiring? Is there anything else that I will need to change? Can someone help me out? Thanks.
[Modified by red92hatch, 5:23 PM 10/17/2002]
Super easy solution: use an OBDI LS ecu and problem solved. You can run a full OBDII motor with the OBDII engine harness but use the OBDI ecu that plugs into your cabin harness. Bolt it in, hook up the plugs and enjoy......... it almost that easy!!!!!
4thgenlude
13
Oct 24, 2006 10:46 AM
