Xenocron.com Write-Up - DIY Install of Innovate, PLX or AEM Wideband to an EMS
Old Sep 16, 2012 | 03:46 PM
xenocron's Avatar
Default Xenocron.com Write-Up - DIY Install of Innovate, PLX or AEM Wideband to an EMS
I get this question in email and phone more than any other I think.
How to I hook up "X" wideband to "Y" engine management system so that I can tune or log Air/Fuel Ratio in my Engine Management of choice.
Well I sell Innovate, PLX and AEM widebands most commonly, and I tune Hondata, Neptune, AEM and Haltech (also sell these systems most commonly) so I thought it fitting to make an all inclusive write-up without gettting TOO technical to help answer these common questions.
...and here it is:
HTML version:
http://xenocron.com/install/Xenocron...etup-Guide.htm
PDF Version
http://www.xenocron.com/downloads/Xe...band-Setup.pdf
Hopefully this helps a few people out there and answers more questions than it creates!
Old Sep 16, 2012 | 11:18 PM
eDm cRxXx's Avatar
Default Re: Xenocron.com Write-Up - DIY Install of Innovate, PLX or AEM Wideband to an EMS
Great write-up!!
Old Sep 17, 2012 | 04:28 AM
ReV LiMiT's Avatar
Xenocron, what if the tune was made and set to Open Loop on a Hondata S300 and converted over to closed loop with the integrated wideband? What kind of changes would have to be made to the calibration?
Old Sep 17, 2012 | 09:30 AM
xenocron's Avatar
This write-up doesnt cover that, but its all in the CLOSED LOOP section of Parameters.
You have to wire it up following the same guidelines as this write-up, make sure you put a check in the box marked "Closed Loop Operation" and then check the box labeled "Use Wideband input for closed loop operation" and a fill out the rest of the details appropriately from there. Not a big fan of using this option on an OEM ECU like this unless everything about the car, wiring, etc is PERFECT
Old Sep 21, 2012 | 08:50 AM
Exodus191's Avatar
Interesting write up, thanks
Old Sep 21, 2012 | 02:03 PM
EF1.8T's Avatar
Very helpful Thanks!
Old Oct 11, 2012 | 09:21 AM
sicones's Avatar
I would like to add for OBD1 systems I would avoid using the D14 (O2) input with a 0-5V wideband, as this input was meant for a 1V sensor, it cuts off at around 3.5V. It would cutoff leaner A/Fs, not a huge deal but I would rather have the full resolution of 0-5V inputs available on D12 or B6.
Also I found a few annoying bugs when using a wideband for closed loop in S300, apparently Hondata can't "reproduce the problem". So if your going to use closed loop get a regular O2 sensor on D14. Or use the second analog output on the innovate gauges which is a 0-1V simulated narrowband connected to D14.
Old Oct 11, 2012 | 12:05 PM
Rtype16's Avatar
Very nice work guys! One suggestion can you add a little piece of information about sensor placement and sensor angle when installed. It seems like everyone does not think this is important and installs it incorrectly which will cause a sensor to fail prematurely.
Old Oct 12, 2012 | 07:46 AM
xenocron's Avatar
That is covered in the installation instructions of each wideband, which everyone should be following already, hopefully
Thanks for the kind words!
crxsiperf
Aug 26, 2006 10:58 PM
.dave
Sep 22, 2003 07:43 PM
symba
Dec 10, 2002 10:01 AM
symba
Oct 22, 2002 06:26 AM
integra1884
May 17, 2002 03:58 PM
