Nitrous help
Old Sep 14, 2012 | 09:25 PM
Jswike's Avatar
Default Nitrous help
Okay, so I've got a fully built ls/v with estimated 11:1 Compression ratio. Internals said to withstand 600 hp. I want to know; how much nitrous can I push in this thing? It will be a daily driver, but the nitrous is for the very rare occasion. So many questions. Opinions on the NOSzle setup? Can I run multiple stages without using separate jets? I would like to achieve around 200 whp all motor, and around 400 whp with bottle. Can I stay pump gas that high? What nitrous controller?
Thanks
Old Sep 14, 2012 | 11:01 PM
90civicstdgold's Avatar
Default Re: Nitrous help
With the amount of money invested in a B series to make 400whp on spray, you would be better off turbocharging this engine. It would be cheaper with the capability of making even more than 400.
Old Sep 15, 2012 | 04:23 AM
grumblemarc's Avatar
The Grumpiest
If you look, this forum is pretty much a black hole. Real tech questions never get answered in here. You should post in, or ask a mod to, move this one to the Forced Induction forum.
Old Sep 15, 2012 | 06:18 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
if you plan on making an extra 200 whp with a single fogger it won't happen. it's still going to take quite a bit with a direct port it.. i would stick with a 75-100 shot on a single fogger until you're comfy with the setup and how your motor reacts to the tune and nitrous. then look into a larger shot. if this is your first experience with nitrous i'd start there.
Old Sep 15, 2012 | 09:55 AM
Jswike's Avatar
Turbo is not a consideration. I didnt want to put this in the FI forum cuz god knows what debate I'd start on whether it is FI or not lol. I agree with you on starting at 100 and going up. But if it takes a direct port system and specific intake manifold to allow it. Id rather start with that then go with a wet or dry kit and then have to replace it
So let's make this happen I need help
newtron63h
Aug 7, 2011 02:36 PM
square_1
16
May 2, 2010 01:51 PM
eg6madness
Jan 27, 2010 12:24 AM
jdmRus
Sep 13, 2005 02:59 PM
Toretto
Feb 25, 2002 05:04 PM
