ZEX NITROUS GONE WRONG HELPP!!
Old Sep 13, 2005 | 12:59 PM
jdmRus's Avatar
Default ZEX NITROUS GONE WRONG HELPP!!
Ok my motor setup is ported gsr head/b16a2 block with srp 11:5.1 Compression and eagle rods, are the major mods done little ones no need to mention. but I just reacently installed a ZEX Wet kit single fogger 75 shots. I noticed that when we activate it only gasoline comes out NO Nitrous! my bottle is turned on of coarse at 900psi where it should be. it goes all the way to the Solenoid or purple cpu. but doest go through the fogger. has anyone incountered any problems like this..
Everything works fine exept the nitrous doesnt want to come out to the other side
I called zex numerous of tiimes really bad tech help.. they dont pick up when they connect you to tech help.. i sat there for 30min 3 times already. waste of time but they pick up really fast tho when your buying something.
Thanks in advance please help!
Old Sep 13, 2005 | 01:20 PM
nota-eg's Avatar
Default Re: ZEX NITROUS GONE WRONG HELPP!! (jdmRus)
This is a nitrous question, should be in FI/N02 forum. I'll have a mod move it.
Old Sep 13, 2005 | 02:26 PM
T4eg's Avatar
Default Re: ZEX NITROUS GONE WRONG HELPP!! (nota-eg)
is the nitrous soleniod clicking? does it have power/ground? If it has all 3 of those then i would say u call zex back up
Old Sep 13, 2005 | 02:59 PM
Kelly.'s Avatar
I've quit using this account
unscrew the n2o line at the solenoid, then open the bottle, this will make sure the line is clear of any debris.
then (with the n2o line hooked up) arm the n2o system and floor it to simulate the system working (car off, but still has power) make sure the solenoid is clicking ( opening ).
if it is NOT clicking, i would check the wiring.
good luck
B16HelpMe
May 23, 2007 09:48 AM
0618turbocivic
Jul 25, 2006 08:38 AM
n2oteg
Apr 14, 2004 01:35 PM
IWearMyKswiss
Dec 6, 2001 08:49 PM
