Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Driveline Vibration 2003 Pilot
Old Sep 13, 2012 | 03:29 PM
oldspriteguy's Avatar
Default Driveline Vibration 2003 Pilot
Just got an 03 Pilot with 152000 Km 95000Mi. .
Drove about 15KM after purchase and a Serious vibration ocurred felt like rear half shaft or drive shaft. Stopped at roadside ,could'nt see any loose bits. Drove off again and no vibration! Went back to used car place and of course the problem would not re-occur. They are going to look for a problem but I'm
not sure they believe me.Service record show regular maintenance by a Honda dealer. Is there a common "problem" with the Pilot? If they can't find a problem, where should I look? Thanks for any and all help
Old Sep 20, 2012 | 06:59 AM
Gearspeed-Performance's Avatar
Default Re: Driveline Vibration 2003 Pilot
The pilot and MDX etc, have a bearing issue that occurs often. This could be the cause of your sporadic vibration. Give us a call and one of our automatic specialists can help you diagnose.
Old Nov 18, 2012 | 11:07 AM
goneb4u's Avatar
might be the vtm rear differential, check service records on oil changes, these will vibrate when oil is in need of change, if you are lucky you will have caught it in time before damage occurs.
billdoodle
Mar 26, 2015 01:18 PM
Shaw14
Dec 30, 2008 01:52 PM
sirjeff
Jun 4, 2003 11:57 PM
DigitalFusion
May 1, 2003 06:10 PM
