a QUIET BOV
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i am a novice in FI world (sort of). i am in need of a quiet blow off valve, around 15-20PSI planned. don't care if recirculating or atmosphere vented.
i would also prefer one without flashy appearance, something like the old Bosch BOVs used in Nissans.
Who is Mr Robot?
they will work, you would need to have a hose barb welded to the charge pipe with a piece of silicone tubing to mount the bov... then you'd have to plumb the recirculation stuff
I have a Tial BOV and when I giddy-up it sounds like the car is sneezing when I shift. Not loud but definitely not stealth. Of course they may believe the car realy does have have hay fever as the whole thing is stealth.
you say you are a novice in FI, but you plan on putting together a system with ITBs, and a custom charge box with an aftercooler in it? ssems a bit complicated for a novice. I don't want to discourage you, but if you are truly a novice you should do alot of searching, followed by a simple first system to get your feet wet. just my .02
Who is Mr Robot?
my neighbor has an srt4 with the mopar block off plate, i never, ever hear his blow off valve... its all in how you drive the car
i have also made a custom ECU and the harness for it
