ls bottom end rebuild problem
Old Sep 11, 2012 | 06:36 PM
m3kid's Avatar
Default ls bottom end rebuild problem
So I just got my crank back from the machine shop. Installed new main bearing rotates good no problem. So i went to install the two pistons from each end and once i torqued it down i tried to rotate the crank but it was had as **** to even get a full rotation at one point it didnt want to move. So i took it apart and my bearing on the rods where kinda scored. I used a good amount of assembly lube. Im using gsr rods with a ls crank. Not sure what could be the problem im might end up using my old ls rods and pistons. Any input on the problem? Oh after i removed the rods and rotated the crank and move freely. And when i didn't have the rods torqued down just hand tight it would spin no problem?
Old Sep 11, 2012 | 06:41 PM
doood's Avatar
been there done that
Default Re: ls bottom end rebuild problem
why are you using gsr rods on an ls crank? you realize they're longer right? what pistons are you using?
Old Sep 11, 2012 | 06:44 PM
m3kid's Avatar
yes lol i actually found that out right now but im still having that problem maybe the gsr rods are no good? and also why would it score my bearings? I guess i got to use my ls pistons and rods
Old Sep 11, 2012 | 08:21 PM
Gunmetal_B20_Hatch's Avatar
arent GSR rod journals thinner than LS?
Old Sep 11, 2012 | 09:16 PM
civickiller's Avatar
did u check the bearing clearances? only thing i can think of is clearances too tight
Old Sep 12, 2012 | 12:56 PM
m3kid's Avatar
ls pistons are doing the same? scored the bearing again
and i didn't check the bearing clearances
Old Sep 12, 2012 | 01:47 PM
turbohatch96y7's Avatar
Buy some plastigauge and find out you have the wrong bearings.
Old Sep 12, 2012 | 02:52 PM
m3kid's Avatar
Will do and also the machine shop said they went with 40 on mains and 20 on the rod journals. Im using the stock rods. There isnt no crank shaft play from side to side and used the two shims for the crankshaft.
Old Sep 12, 2012 | 03:30 PM
doood's Avatar
so you're assembling an engine without checking bearing clearances?
Old Sep 12, 2012 | 03:35 PM
m3kid's Avatar
lol yea i thought it would be straight forward
Old Sep 12, 2012 | 04:26 PM
doood's Avatar
with you not checking clearances and not knowing ls and gsr rods are not the same length, do you think you should really be assembling this engine? do you even have the correct torque specs and sequences?
Old Sep 12, 2012 | 04:57 PM
m3kid's Avatar
yes ma'mm I do. I also went by using the zealautowerks calculator and i thought - was still sitting below the block on the ptd height. Well Iv been reading forums that maybe the machine shop gave me the wrong rod bearings so I have to go up there tomarrow and see if they did. thanks for the help so far
Old Sep 12, 2012 | 05:26 PM
m3kid's Avatar
so just for giggles i went to install one of my ls pistons using tge old rod bearing and torqued it down and it actual span freeley no problems. So that leads me to believe the machine shop ordered the wrong rods bearings.
Old Sep 12, 2012 | 06:43 PM
the rods can be different sizes so if your rods are different size it wont match clearance wise
Old Sep 13, 2012 | 06:32 AM
m3kid's Avatar
Yea im going back to the machine shop today they said they might have ordered the wrong bearings.
Old Sep 13, 2012 | 06:40 AM
kyden's Avatar
just give it to them, have them assemble it. that way if anything goes wrong, you can blame them. gsr rods on an ls crank would have your pistons out of the hole at TDC.
Old Sep 13, 2012 | 10:55 AM
m3kid's Avatar
yea i know that im using the ls rods now but im pretty sure they gave me the wrong bearings Im going up there in a little to see whats the problem
Old Sep 13, 2012 | 04:41 PM
m3kid's Avatar
ended up kinking the crankshaft with one of the rod bolts
Old Sep 13, 2012 | 09:40 PM
FAIL!!!!
Old Sep 14, 2012 | 04:11 AM
m3kid's Avatar
Originally Posted by turbohatch96y7
FAIL!!!!
:shrug
Old Sep 14, 2012 | 04:47 AM
rxrotorless7's Avatar
At this point I would hand it over to the professionals to put it together. Also, get yourself a factory service manual and take your time reading it...
Old Sep 14, 2012 | 08:29 AM
m3kid's Avatar
Yea they are going to assemble it for me welp now I know for the next time
leroyb
Apr 12, 2009 07:45 PM
civicking99
Nov 12, 2007 04:25 PM
esteen2
19
Mar 9, 2005 08:59 AM
Greg-s
Dec 28, 2004 10:11 AM
1.8T_EG
Mar 27, 2003 06:36 PM
